Question about Garden
Alpina strimmers vip21
Which way does the line holder unscrew to change cord
2 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: how do you change the cord on a b and d strimmer
Hi, W/D here.
Pull the spool straight off, out of the head. Look at the bottom of the spool, you'll see arrows indicating the direction that the line should be wound. Now, look at the spool. You'll see that there are actually two spools, made together. In the middle part of each spool, you'll see a small hole. There should also be a notch in between the two spools.
OK. Starting with the inner spool, insert your line into the hole about 1/8", and wind in the direction of the arrows. When you have wound the line to the diameter of the divider between the spools, stop. There is a very small notch on the bottom of the spools that is 180 degrees from the notch in between the spools, and at the bottom edge of the spool that you are winding. Click your line into that notch. Leave about 6" of line out past the notch, and cut it off from the pack of line that you are winding from. Now, wind the outer spool the same way. When full, you'll guide your line thru the notch between the spools and into the small notch at the bottom of the inner spool. Leave another 6" tail, and cut it off.
Take the two tails of line while holding the spool,and insert one into each grommet on the machine head. Align the line notches with the grommets, and press the spool into place. You should feel it click into place. Now, you want to tug on the line tails to pull them out of the notches. You're done!
I have one final bit of advice, and you don't have to do it this time...just keep it in mind... The head will sometimes be stubborn in dispensing the line. I find that occasionally putting a little graphite into the hole where tha spool fits onto the machine helps the line advance part work much smoother, and it keeps the head from sticking.
Best regards, --W/D--
Posted on Aug 14, 2009
How do I change champion strimmer cord
this is the pdf user manual for it
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfChampion Strimmer Manual - 64.140.158.30 homelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s manual your manual ...
Jul 17, 2016 | Garden
Champion strimmer 25 cc cord
its a pdf
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
How to change oil on 2007 alpina b7
Just like any other cars. The oil filter is located right behind the oil pan, they can drain at the same time. I usually put in 10 qts of oil with filter change, which does not reach all the way top of the max line on the dip stick.
Feb 14, 2013 | 2008 BMW ALPINA B7
How to thread a strimmer instructions
Top half you wrap the trimmer line in the direction shown .Bottom half in opposite direction.. Question not very clear ?? Ken
Jun 08, 2012 | Black & Decker Hand Tools
I cant remove the starter coupling from my husqvarna 124L line trimmer.
It should unscrew off the back of the strimmer, then there should be a screw holding on the spool.
Oct 29, 2011 | Husqvarna 28cc Gas Line Trimmer
Broken cord
Pull cord or strimmer cord.?
Jul 26, 2011 | Husqvarna 28cc Gas Line Trimmer
Trying to find out the age of an Alpina silver pocket watch with a serial number 130155
Only ALPINA can give you correct answer. Follow this link and contact ALPINA yourself: http://www.alpina-watches.com/en/contact/retailers.php Rate me, plz.
Feb 28, 2010 | Watches
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
