Question about 1991 Thunderbird / Mercury Cougar EVTM Electrical and Vacuum Troubleshooting Manual
I have a 1991 Ford Cougar with a Code E2, and E7 coming up in the temp read out window of the heater, and fan will work but can't get any Heat
    New Friend:
  • 175 Answers
Check the blind or air mixing door
Posted on Aug 27, 2013
Radiator fans not coming on. replaced thermostat and cooling sensor
Hi Bill, is the engine actually getting hot enough for the fans to come on? if the engine does have overheating problem (but you say the temp gauge reads normal) then i would check the operation of the engine temp switch, there are two, one for the gauge and one for the fans.
Oct 15, 2016 | 2006 Ford Escape
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
99 mercury cougar v6 2.5L, temp gauge is reading hot after thermostat change why? is it a air bubble or is it a bad temp. sending unit? any other ideas? please help
May be a defective thermostat or place in the wrong direction. If it's properly installed, might want to check the fan operation which may be producing the overheating.
If fan is good, one way to remove air in the coolant system is to run vehicle while all heaters on. take extra coolant and stop along the way to top off if needed. While driving, keep listening for the fan to begin running when vehicle reaches high temperatures.
If you continue to experience overheating, may want to take to a local known repair shop for further troubleshooting.
Jun 17, 2017 | Cars & Trucks
What's your problem?the fan for the heater quit working
I'm assuming the heat for the inside of your car. Does it work at all? On any of the speed setting? If it doesn't check fuses, check for power and ground at fan. Or if you can see it just bang on it with your fist sometimes that will get it working temp.
Dec 21, 2011 | 2003 Ford Taurus
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
Ford focus 1.6 tdci engine management light has come on water temp crept up slowly but dropped when heater switched on any ideas?
Hi,i had similar problem,the fan wasn't working.When i turned heater on hot it released the heat from the engine & temperature went back down.Turned out my fan relay fuse had blown.$5 fixed the problem.Hope this helps.
Feb 14, 2011 | 2005 Ford Focus
GMC Sonoma SLE 4.3L 1991- Coolant Temp Gauge Not reading
there are 2 coolant sensors one for gauge and one for ecm
Jul 23, 2009 | 1991 GMC Sonoma
Temp Gauge Reads Hot all the time and no heat
double check the fluid level again, other option is a blocked heater core
Jan 26, 2009 | Ford Escort Cars & Trucks
No heat after changing thermostat
i mean heat and cooling for the seat, which control are on the door
Dec 16, 2008 | 1991 Ford Escort
1991 Thunderbird / Mercury Cougar EVTM Electrical and Vacuum Troubleshooting Manual Logo
108 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
