Question about Water Heaters
Low water pressure in one area of house - Water Heaters
  • Water Heaters Master
  • 5,245 Answers
Copy following link:
http://waterheatertimer.org/Low-hot-water-pressure.html
If one area of house is affected, then clog is usually at elbow or connection point.
Remove water shut-offs, and use compressed air to see if clog can be jostled loose.
Posted on Apr 29, 2013
I have a siemens rcr 10/433 with low water pressure. How do I increase the water pressure?
Do you have supply valve to water heater? if so make sure it is wide open. How old? Warranty? Owner's manual troubleshooting? How do you know it's too low? Error code? Could be sensor. If it's a recent problem do you have any leaks between water meter and inside plumbing? If all water is off in house water meter should be motionless. Usually a red triangle will spin fast if there is a leak or water running in the house.
Mar 08, 2015 | Water Water Heaters
How can I increase the hot water pressure in my home?
Cold water pressure is what give you your hot water pressure so they should be equal but if you have a restriction on the hot side such as a valve not opening on the hot side or not opening all the way then you will have less pressure or the pipe work on the hot side is not proper. Hard to say but check the valve on top of the hot water heater
Aug 13, 2014 | Water Heaters
Low water pressure
1) Copy following link for troubleshoot walk-thru:
2) Yes. Remove the heat-trap inserts from water heater.
3) Add comment and say where you are so far.
Dec 30, 2012 | Water Heaters
Water pressure decreases as the water runs
Probably a clog in galvanized pipe.
Expansion tank is not whole-house pressure regulating tank. It is localized protection for plumbing exposed to high pressure caused by very hot water.
If you house has pressure regulating valve, then that can be a cause.
For low water pressure in household, the following link might help:
Aug 07, 2011 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I replaced the pressure relief valve but still leaking
Might need to install/ replace the pressure reducing valve between the house and water supply.
Mar 13, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
21 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
