Question about Jenn-Air JCD2295KES Stainless Steel
Service manual Water dispenser will not shut off
  • Jenn-Air Master
  • 4,654 Answers
Having a water dispenser continually flowing is possible but it is very possible the 67006531 Dual Water Control Valve that is located on the back and near floor of most refrigerators is stuck open mechanically. There also could be a broken micro switch behind the pressure paddle where you press you glass against to get water. Here is a JCD2295KES Service Manual I believe you asked for. I am here should you have questions, Thanks Sea Breeze
Posted on Apr 28, 2013
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Wont dispense water or ice
Hello;
My name is peter. I am a retired field service refrigeration technician.
There are only two possible causes.
1.) Either you have a bad water filter, which happens. remove the water filter and test your water dispenser.
2.) Your water supply pressure is bad. Sometimes the water shut off valve to your unit gets plugged up. You need 60 PSI water pressure to operate the solenoid valves to your Ice maker and water dispenser.
Dec 08, 2014 | Refrigerators
Electrolux water dispenser wont shut off
If your water dispenser will not shut off then it is either the dispenser microswitch or the water inlet valve in the back of the refrigerator. Here is link that might help http://apcoappliancerepair.wordpress.com/?s=water+dispenser . Would need a model and serial number to assist you more. Good Luck From Apco Appliance and Air .
Apr 19, 2013 | Electrolux Refrigerators
No water from despener
Most times the problem is caused by the dual water control valve that controls the water dispenser. Other things could be frozen water inside the water filter assembly, lines or dispenser. Also problems with the dispenser controls=> WR55X10446 Location number 93 => HSS25GFPAWW Freezer Door and Dispenser
WR57X10051 Water Control Valve
Here is a=> Service Manual Please remember that the service manual covers all models related to yours and some parts in manual will not be related to yours.If you would like to test the water control valve carefully apply 110 VAC to the water dispenser side or check the coil with an OHM meter. I will be here to answer your questions if you need more answers but at this moment I feel the problem is the dual water control valve , Thanks, Sea Breeze
Jun 28, 2011 | Hotpoint HSS25GFP Side by Side...
Can not shut off water dispenser. Must open door. Then put it in lock position
The best way to find which part of the dispenser control that may be causing the dispenser to remain on is to unplug each part that leads to the dispenser keyboard until found. The service manual for your model JSD2789GES seems to point to the keyboard yet when I look for parts the only part that is shown is the circuit board behind the keypad. It may be part of the replacement circuit board=> 61005274 Dispenser Control Board you can ask these people if the keyboard is availabe and they will be happy to help you. I would normally send the service manual here but Maytage ask me not to do that. You can request the Service Manual through Here Just ask for the JSD2789GES Service Manual and I will be glad to help you and glad to help you get this fixed, Thanks Sea Breeze
Jun 15, 2011 | Jenn-Air JSD2789GES Side by Side...
I just replaced the water filter in my Maytag French door refrigerator (2 yrs old) and now the water/ice dispenser will not operate. All other functions on panel are fine (alarm, light, etc.). I tried to...
Hi, there is a micro-switch at the filter which shuts off the supply and operation while the filter is out of the unit. That switch is still open, so the dispenser thinks you are still replacing the filter. Try taking the filter out and putting it back in. Make sure any locking mechanism is fully engaged. In the meantime, I will see if I can find the service manual for your unit.
Jan 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Bleach will not dispense
You will need the Service Manual for reference. Sears Parts Direct for reference.
Do you have water flow to the dispenser? You can turn on the dispenser water valve in Service Mode and check for operation.
Non technical troubleshooting would be to enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Bulky Items Key. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Bleach dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach dispenser valve.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
The Part Number for the Dispenser Valve is 25001043 Google for best price. Post back if you have questions..........Rich
Pic of the valve on the work bench;
May 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softener dispensor does not empty
For the FAV6800A or FAV9800A:
If you have no water flow to the Softener dispenser or Bleach dispenser see if you can turn the dispenser valves on Service Mode and verify water flow to the reservoirs.
Enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the Fabric Softener dispenser water valve. Did you hear the solenoid hum? If so we will now need to turn on the Cold Water Inlet Valve and see if water flows to the dispenser.
Now press the Spin Only key this will turn on the Cold Water inlet valve after 5 seconds press the Off key. The washer will unlock. Check to see if water did flow to the fabric dispenser reservoir. If you heard the Fabric dispenser valve hum then most likely 120VAC was applied to the solenoid. If water did not flow then the Fabric dispenser valve is stuck closed if you heard it hum.
The Bleach/Fabric dispenser water valve is an assembly and is not repairable you have to replace.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Fabric dispenser solenoid.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price try appliancezone.com…
You can remove the Fabric Softner to clean see page 33 of the Service Manual…Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Open Questions:
See all Jenn-Air JCD2295KES Stainless Steel Questions
Jenn-Air JCD2295KES Stainless Steel Logo
90 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
