Question about Kenmore 24032\24036 Top Load Washer
Clean filter kenmore 80 series washer - Kenmore 24032\24036 Top Load Washer
    President:
  • Kenmore Master
  • 662 Answers
Check for blocked pipes below tub and exit drain hose, after disconnecting mains; no filter as such. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Posted on Apr 30, 2013
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
  • 99 Answers
SOURCE: Kenmore 80 series
sounds like your control switch needs replacing.
Posted on Apr 30, 2008
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
SOURCE: I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Posted on Jan 22, 2009
JULIANFIX
  • 975 Answers
SOURCE: How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Posted on Oct 26, 2009
How do I clean the filter?
there is NO filter in a washer,use a refresh washer cleaner to smell good,
Mar 26, 2015 | Kenmore series 70 80 90 Washer timer...
Kenmore 80 series washer is it energy efficient
yes
and
yes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 06, 2010 | Kenmore 24032\24036 Top Load Washer
Mildew smell in washer
there is a chemical you can get to help with the smell from SMELLYWASHER.com
Feb 19, 2010 | Kenmore 22942 Top Load Washer
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
Nov 11, 2009 | Kenmore 24902 Top Load Washer
80 Series Top Load\ Water Feed
There may be a screen in the inlet pipe where it joins the back of the machine. Also check that the inlet pipe is clear and running water correctly before connecting it back on the machine. If this is OK you may have an issue with the inlet valve not opening fully. This is quite a common issue and will need the inlet valve repalcing.
Sep 12, 2009 | Kenmore 24032\24036 Top Load Washer
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Mar 01, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
217 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
