Question about Symbol Motorola MC3090 Handheld Computer
Scan wedge missing on mc3090
No scan wedge and in french not english
How do you use the symbol mc3090 to 'quantity' scan multiples of the same item?
No need for further troubleshooting yet.Just try to format sd card and check for any invalid or unnecessary files on the handheld and delete it_cold boot then try scanning items again.
Jul 31, 2011 | Symbol MC3090 (MC3090GLC38HB0GE) Portable...
I need help in configuration of Scanner from Symbol MC3090. I want to scan a I2of5 Barcode which is 20 digits long. But the scanner did not scan it. We have a mobile application that is used to scan...
The length of the barcode is usually setuped in the the scanning application to avoid an partial scan or missdecoding. Please checkthe scanning options and stup the egth to 20 characters
Aug 04, 2010 | Symbol MC3090
I want MC3090 scanner work with notepad or microsoft word
you can't scan directly into either of these programs. you have to scan with the scanners own software or in a graphics program and then insert the file.
Dec 28, 2009 | Symbol MC3090
MC3090 is having trouble scanning 2D labels. It
No...check the printer that is creating the 2D code. It's probably the culprit. Make sure the head is perfect and the 2D code is big enough. The 2D version of the MC3090 doesn't read small 2D codes.
If it still doesn't work, contact your dealer or the Moto Help Desk at 1-800-653-5350
Oct 22, 2009 | Symbol Motorola MC3090 Handheld Computer
Why my MC3090 Scanner doesn'n scan when i open Microsoft Wordpad?
You would need to install and run an scanning application. On the suppor.symbol.com webpage is the application Datawedge available.
Oct 07, 2009 | Symbol MC3090
Data loss while scanning a 2d label. it is not capturing entire contents
If you are using data wedge to scan then it needs to be configured. I can provide steps necessary for this request. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Sep 28, 2009 | Symbol Motorola MC3090 Handheld Computer
Motorola MC3090 do not read barcode starting with zero
look online there are learning barcodes out there you can scan, look for one with zero in front, if you are making the barcodes yourself than put a * at the beginning and end and then make barcode, it will capture everything in between,
Aug 26, 2009 | Symbol Motorola MC3090 Handheld Computer
Scanner is in French/ need English/ printer is in english
Press
MENU
SCAN
COPY
SCAN
That will enter Service Mode.
Right arrow to #5 and press OK
CYGNUS-1 for the MP750 and OK
Select "standard region".
Then press the power button off and on, when it comes on you should be able to select language.
More here - http://damnprinter.com/165/canon-mp750-and-mp780-cd-printing-instructions.html
Cheers!
Apr 26, 2009 | Office Equipment & Supplies
Problem with barcode scanner
Interleaved 2of5 symbologies is normally disabled from factory. what scanning software are you using? have you tried Datawedge to enable the scanner? Is a free download from symbol/motorola and it goes very well.
Mar 05, 2008 | Symbol MC3090
Symbol Motorola MC3090 Handheld Computer Logo
56 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
