Question about AEG L16820 Front Load Washer
Aeg e40 - AEG L16820 Front Load Washer
2 Suggested Answers
  • 266 Answers
SOURCE: WHAT IS ERROR E40 MEAN?
Its a defective door lock. It might have to be replaced by a techie! Hope its under warranty
Posted on Mar 08, 2014
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
AEG Lavamat washing machine model 76850, shows a blinking key and makes clicks and after that shows E40. Thanks John
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensing circuit faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Aug 02, 2014 | AEG Washing Machines
Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Turned off mid cycle. Tried putting back onfor drain, also rinse and restart. Each time get error E40.
Hi.
With AEG washers E40 means defective door lock. Since a faulty door lock switch may go out with vibration you often do not get the error all the time. The door lock switch must be tested and eventually replaced. Call the AEG number listed in the user manual if you want to get in touch with an authorized technician or if you need replacement parts for your washing machine.
Regards.
Ginko
Sep 18, 2011 | AEG Washing Machines
AEG washing machine error code e40
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.After the door is closed again the fault should go away. If it does not and you hear alot of clicking from the door lock you may just have a door lock at fault.Code E40 is door not closed, could be a mis-aligned door or faulty door switch.-------------But if door is closing properly and you are confirmed that door is getting properly locked, then other possibility can be gunked filter or blocked drain pump.It requires cleaning internally.The procedure is as follows:--- Towards the bottom right of the machine is a pull-down flap.
Drain the machine - there's a tube at the bottom of the machine
with a plastic plug - you'll see a butterfly handle, pull hard; the plug
is a round ball on the end of a stick.
Unscrew the large diameter thing (pump cover) -
Don't do this before the drain step!!!
Withdraw the filter cylinder and remove any gunge - the
filter port has two ports - the left one is the impellor
pump and the right one is the discharge pipe; feel to ensure
these are not gunged up either.
Reassemble in reverse order - as Haynes say.
Almost every programme necessitates a pump activation to
assure that the machine is empty of water .-----------
Apr 09, 2011 | AEG Lavamat 74640 Front Load Washer
Aeg lavamat error 40e
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board.
Feb 04, 2011 | AEG Lavamat 72640 Front Load Washer
Aeg 74640 error code e30
What does the E40 error code mean?
Jul 09, 2008 | AEG Lavamat 74640 Front Load Washer
Error message
e40 fault code is water level too low during heat which is very strange to appear at start-up. does anything else happen? without being certain, points to a main module fault
Dec 23, 2006 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG L16820 Front Load Washer Logo
19 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
