Question about Garden
Honda gv 100 oil in air filter
Oil in air filter
4 Suggested Answers
  • 297 Answers
SOURCE: I HAVE MISLAID MY INSTRUCTION BOOK FOR MY HONDA
2 stroke engine 5% like on my litle motorbike.
don't go for that cheap oil that sticks.
Posted on Apr 14, 2009
  • 97 Answers
SOURCE: engine just started burning oil and loosing power.
sounds like you have a blown head gasket....pull spark plug and check for oil on plugs....thats your bad head gasket
Posted on Jun 12, 2009
  • 11 Answers
SOURCE: gv 250 wont stay running
Engine stalls
easily.
1. Fouled spark plug.
2. Clogged fuel hose.
3. Clogged jets in carburetor.
4. Valve clearance out of adjustment.
Clean.
Clean.
Clean.
Adjust.
Posted on Sep 07, 2011
Honda wave 125 producing white smoke
First clean your air filter element, a clog air filter means air will be forcebly sucked from your engine together with engine oil producing white smoke. Or it can be worse, a broken piston ring, you need to change a set of piston ring. do not run your engine if it has a broken piston ring cause it will damage your cylinder block and will cause engine seizure.
Feb 17, 2014 | 2005 Honda NF 100 Wave
I have 2002 GV with 104,000 KM but, the transmission oil is not very clear. Dealer suggests to flush it and that is what they do, shall I go for that or do it properly with filter...?
pink is good, darker is bad, for Dextron x ATF.
use the highest # Dextron it is 100% backwards compatible.
ok first time? best is 50k.
you only have 3 choices.
1: do nothing
2: drain and fill (+filter) gets 1/3 of the lube.
3: full flush, + filter.
i just did my 04 GV at 90k.
its happy.
but if you read 1000000 posts on A/t full flushes, your mind will turn to mush..and UGH !.. yes, abused tranny, may flush out crap.
a/T always is a crap shoot with that, tiny passages, and can clog.
A/T are a pain that way. (next time get a M/T !)
It is your call, your risk, but id do the FF ever 50k, sure would.
Nov 12, 2013 | 2002 Suzuki Grand Vitara
1996 Honda VT 1100 C2 Shadow Sabre oil in the air filter box
Hi, Wayne and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Oil in the air box
Honda Shadow Spirit air filter sub air cleaner crankcase breather
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
May 29, 2012 | 1996 Honda VT 1100 C2 Shadow Sabre
I am looking for what an error code is: B with a 12 under it.
Code B12 is your 10,000 miles check up:
B: oil & filter change
1: tire rotation
2: engine air filter, cabin air filter change
Reset Meter:
1: turn car to ON (II)
2: press sel/res button until oil life % is displayed
3: press & hold sel/res button until oil life blinks (10 seconds)
4: release button
5: press & hold sel/res button until oil life shows 100 (5 seconds)
Hope this helps (remember to rate this answer). Good luck.
Feb 23, 2011 | Honda Odyssey Cars & Trucks
I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Oct 10, 2009 | Honda 25cc 4-cycle Mini Tiller
Gv 250 wont stay running
read my solutions on this site for clogged carbs.....Tim
Jun 01, 2009 | 2002 Hyosung GV 250 Aquila
Honda ruckus oil on air filter
There shouldn't be any oil on the air filter. Take the air filter out and try drying it out (a blow dryer would come in handy) to make sure the liquid is not water. If it is oil, take it back to the dealer as it is still under warranty.
Apr 03, 2009 | Hartford VR 150X Motorcycles
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
