Question about Garden
Show V belt configuration diagram - Garden
  • Garden Master
  • 2,478 Answers
What year model and make. Deck or drive.
Posted on Apr 28, 2013
Power steering, water pump, air conditioning, alternator, belt configuration diagrams, please
hundreds of configurations so no one can help unless you realize that make , model, year are all required to focus on the answer
Feb 11, 2016 | Cars & Trucks
Tip
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/1246110?modelNumber=LDE8424ACE#repairHelpVideoTabs
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
Do you have a diagram for the belts on a 1978 1 ton Chevy van?
Every 1978 Chevy van was shipped with a sticker affixed to the engine shroud, showing a diagram of the belt threading. If this sticker is lost, you're a little lost as well, since the belt threading varies with engine and optional equipment (such as air conditioning, California emissions, power steering, etc.).
Your best bet if you can't find the sticker is to do an Internet search for "1978 Chevy belt routing) and see which engine configuration most closely matches what you have... and install the belts THAT way. Sorry I couldn't provide a definitive answer!
May 21, 2015 | Chevrolet Cars & Trucks
I'm trying to fix my dryer. The belt broke and broke the idler pully with it. I've got both replacments, but am having trouble keeping the belt from running out of the groove on the drum and...
This link here http://www.repairclinic.com/Dryer-Belt-Diagrams shows the proper configuration of how the belt fits onto the motor/idler pulleys perhaps this will help you to keep the belt on by checking thats its properly on the motor&idler pulleys. Just find your brand and veiw the diagram.
GENE
Sep 04, 2011 | Dryers
Need diagram of belt installation for dryer DV218AEW
Hi mcpitts...
Click on the link to find your model number link http://www.repairclinic.com/Appliance-Parts
Here is the process for taking your dryer apart mentioned above.
You will need to decide which video fits your machine appearance.
Please take time to rate me
Aug 10, 2011 | Samsung DV218AEW Electric Dryer
Lookng for serpentine belt routing diagram for 1998 2.4 L sunfire
1998 Pontiac Sunfire Belt Routing Diagram
A drive belt routing diagram is needed when replacing a drive belt to help simplify the installation process. The problem arises as there are many different ways a drive belt can be configured. In this configuration the belt length will vary not allowing the belt to be installed. Also alternative configurations could turn a particular accessory the wrong direction, creating more problems. Always reinstall the drive belt in the exact configuration as the previous belt to prevent these problems. Always use high quality replacement products to avoid premature drive belt failure. If a multi rib drive belt fails it must be replaced immediately to avoid such situations such as engine overheating and loss of the power steering system. Whenever a belt replacement is required inspect the pulley condition to ensure there are no sharp edges on any of the pulleys, this will cause the belt to shred and fail. Confirm that all pulleys are free from debris such as small pebbles, these pebbles will cause the belt to pit and significantly impair the belt performance. The belt tensioner plays an important role to the drive belt performance, if this tensioner is weak it can allow the belt to lose tension allowing the belt to jump and skip. This condition will result in noises such as squeaking, chirping and ticking.
Hope helps (remember rated this help).
Jul 11, 2010 | 1998 Pontiac Sunfire
Belt diagram
Hope helps (remember rated this).
Jul 11, 2010 | 2004 Chevrolet Cavalier
1995 lexus es 300 serprntine belt diagram
Go to the web site link below (copy and past the web address)
http://www.daycoproducts.com/daycoweb.nsf/cf652a4feb630ad0862571a4005ae40c/a866a821123f887c862571a5006988df!OpenDocument
There are 2 PDF documents to open from that page (above the picture).
The first (Routing guide) gives you the belt routing diagram code for your car (diagram 6-10).
The 1995 lexus ES 300, GS 300 and Sc300 all have the same engine and belt configuration so refer to the 1995 GS300.
The second PDF (Illustration) shows the belt diagram for code 6-10.
Hope this helps.
Cheers.
Dec 06, 2009 | 1995 Lexus ES 300
Need to see a diagram of how to install a craftman lawn mower drive belt for 917.250482
Go to Sears Parts on line, it will show an exploded view of the belt in the configuration that is required
Sep 14, 2009 | Garden
Need belt configuration for 46" deck of craftsman mower
there will be a sticker showing the belt routing, on the back of the deck [rear] in the middle, or on the left, top side of the deck
Aug 30, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
