Question about Sharp FO 77 Roll paper Thermal Fax
Scanner When I fax my image is smaller then the original size that I sent. What could this be?
    New Friend:
    Problem Solver:
  • 10 Answers
You should check the settings in your fax machine. it is possible it is set to send the fax with 90% of the original image size.
Posted on Apr 28, 2013
Why canon pixma p200 only can copy ltr why it cannot proceed to a4
A$ is not a U.S. size. you should although be able to override it in the menu mode, but it will be smaller and may cut off text or image.
Mar 12, 2015 | Canon 2 Original Printer Inks For Pixma...
How to send fax from paint
Faxes are sent by the scanner. Print out the image from Paint then place the print in the scanner then fax it.
Dec 14, 2012 | HP OfficeJet 6110 All-In-One InkJet...
How do you adjust the size [eg, make it larger] of a scanned print,for a final print,for a Umax Astra 1220U
Scanner will scan actual size only. If you need smaller or big sized print, select appropriate size and use 'fit' command before printing. With Raster Editing software, you can create another Image which is smaller or bigger.
S. Mohan
Sep 03, 2010 | Office Equipment & Supplies
1120l Ricoh Fax Machine which can receive a perfect fax but when sending a fax the receipt part which shows a reduced page of the fax sent is completely grey and the fax received at the other end is also...
If it can receive a perfect fax but the problem is only with the image it scans, then the problem lies with the optical portion of the fax machine. Try cleaning the glass where the fax machine scans your original -- it may just be dirty or there may be some white-out stuck to it.
To clean it, just use a damp lint-free cloth and wipe it down, then dry it and try faxing again. If the problem doesn't change then the issue is underneath the glass -- the scanner's lens or mirror may be dirty.
Jul 06, 2010 | Office Equipment & Supplies
Scans @ 75-80% of original size..how do I get it to scan @ 100%
the only thing I can think is the scan or print settings on the printer itself. there should be a way to adjust the size from either the printer or the preferences on you computer in the print screen.
Feb 27, 2009 | HP Officejet 6310 All-In-One InkJet...
My scanning files are to big
Since there's not much information, I'm going to have to make a lot of assumptions with this solution.
The basic issue you have is not the scanning, it's the scaling after the scanning. Since you do not indicate what software you are using to scan the image, I can't be certain without knowing what you're using, but most of these scanning packages allow you to 'resize' or 'scale' the image. How much to scale depends on how large the original is, and how small you need the final version, so some experimentation may be in order. As an example, with my scanner, I typically resize to about 50% of the original.
If you don't have that option, most graphics programs allow this fairly easily (you simply save, then open the scanned image in the image editor and perform the scaling there). Or, some programs even let you resize without opening the file, such as Microsoft's free Image Resizer tool (http://download.microsoft.com/download/whistler/Install/2/WXP/EN-US/ImageResizerPowertoySetup.exe) which allows resizing by right clicking on the file name.
Jan 26, 2009 | HP Scanjet 5590 Flatbed Scanner
Fax problem
Something is blocking part of your scanner light, or scanner light may be bad. Check if the scanner light comes on, and check inside the original feeder and machine for a scrap of paper blocking the scanner light to the imaging drum.
Nov 26, 2008 | Brother IntelliFax-2820 Laser Fax
Sharp FO 77 Roll paper Thermal Fax Logo
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
