Question about Metra 2007-2008 Suzuki Xl-7 Luxury Antenna Cable Audio Radio Installation Stereo
Ecu code p2190 suzuki - Metra 2007-2008 Suzuki Xl-7 Luxury Antenna Cable Audio Radio Installation Stereo
What is error code 33920-76JB2 on Suzuki Jimny
no year year, no joy
this is uSa forum not one JIMNY here, zero , nada, parts or books.
that is not an error code!
the ECU has 33920-76Jb2 part number on sticker side
33920 means ECU in Suzuki PARLANCE.
post a problem
and scan it
Mar 17, 2017 | Suzuki Cars & Trucks
What does an F1 fault code on a Suzuki c50 mean
Hi, Steve for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to Read Factory ECU Codes FI C12 Suzuki 90 Crankshaft Position Sensor
SUZUKI MOTORCYCLES FAULT CODES
99500 38047 03E pdf service manual "FREE"
OEM parts for Suzuki
99011 43H50 03A pdf owners manual "FREE"
Mar 09, 2017 | Suzuki Boulevard C50 Motorcycles
What is the pairing procedure of ecu with immobilizer of Indica vista
TATA Indica Vista ECM / ECU - YouTube
? 2:26
https://www.youtube.com/watch?v=rRk5zSFA1eg
Mar 8, 2014 - Uploaded by Flip Keys
This video shows how to open TATA Indica Vista and ManzaECM / ECU for repair purpose.
How to extract Immobiliser Chip from Indica Vista key ...
? 0:52
https://www.youtube.com/watch?v=pqG0T99Xce0
Nov 8, 2012 - Uploaded by Flip Keys
If your original Indica Vista key breaks, wears-out or gets damaged then you can re-use its immobilizer chip ...
Maruti Suzuki SX4 ECM / ECU - YouTube
? 2:37
https://www.youtube.com/watch?v=pWjmh1QUhHQ
Jan 12, 2014 - Uploaded by Flip Keys
If you are repairing Maruti Suzuki SX4 ECM / ECU or coding a new immobilizer key then you can open the ...
TATA Motors INDICA VISTA Owner's Manual - ManualsLib
Jan 08, 2016 | Cars & Trucks
K14b ecu swift check engine light on short in ecu
the operators guide is clear. CEL on , get car serviced. (at a real ASE service shop)
or if savvy DIY person?, scan it your self.?
with a thing called a scan tool.
(barrow, beg ,rent or buy) avoid the zone.
what does SHORT mean.
lamp flashes short.
blowing fuse due to an electrical SHORT?
which fuse.
post more symptoms, the above is not clear.
Jul 29, 2015 | 2010 Suzuki Swift
What are codes P2190 & P2188 related too
more info like make of car and year
Sep 04, 2014 | Cars & Trucks
No spark from 1 ign coil on suzuki baleno 1.6
wow , no year, but did show G16 engines.
Grand, is a clue. but is not.
wiki facts: so what country is your car, we are USA here,
and we have not one Baleno here.
the Suzuki Baleno throughout Asia, Australasia, and Europe. In India where it was manufactured by Maruti Suzuki, the Cultus Crescent was sold as the Maruti Baleno
Ive not seen Every version of every G16 engine suzuki made
world wide, only OURS.
1995 to 2007
my wild guess, is your ECU is OBD1 ecu, (do you know?)
and as such, there are no scan tools so only the CEL blink codes
work.
No spark 5 places, 4 sparks dead and coil HV tower term dead.
here is the checks. for all early G16
  1. fuses good, IG-coil and "FI"????
  2. key on head lights work, good turn them off.
  3. keyon CEL glows, (not blinks) if dead fuse blown, if flashing Immobilizer is UNHAPPY.
  4. CEL glows you crank, its lost spark and all ecu cut fuel no spark.
  5. So you insert the diagnostic jumper wire. in the the DLC connnecter under hood and CEL flashes 41 or 42 DTC or?
  6. bingo? code 12 is happy code.
  7. crank for 5 full seconds to see the cause code.
here is the OBD1 year, way to get flash codes
USA until 1995
and outside USA up to 2001 or more.
http://www.fixkick.com/CEL/CEL.html#OBD1codes
no year, makes this very hard,
and no country x10 that. (fueling and spark system vary by COUNTRY !
Jul 08, 2014 | Suzuki Grand Vitara Cars & Trucks
Troubleshooting code P2190
Four digit codes are brand specific. Code 2190 for Ford products may mean the fuel mix is too rich for bank two.
Jan 22, 2014 | 2006 Ford Mustang V6
Error p2188 p2190
what model car, suzuki, and engine type.
p2 = factory only scan DTC codes.
you need a factory FSM to solve that.
no two makers of car uses same P2 codes. so don't google them, only suz. codes.
Apr 26, 2013 | Suzuki Cars & Trucks
Error p2188 p2190
p2 is suzuki only factory code.
for some cars , it means rich, i do not have any 2007 suz, FSM.
Apr 26, 2013 | 2007 Suzuki XL-7
Hi:i have volkswagen(golf.2002)1400motor i have problem in ecu am change but i want to programmed this new ecu to code. my email:eng_haniwahid@hotmail.com
to code the ecu you need a vas-5051 scan tool with internet connection and vw-dealer credentials. aka only the dealer can do this.
Feb 25, 2010 | 2005 Suzuki XL-7
Metra 2007-2008 Suzuki Xl-7 Luxury Antenna Cable Audio Radio Installation Stereo Logo
35 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
