Question about Plumbing
Moen plumbing product
Low water pressure. Is there a removable restricter in this product?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
Exactly what is "this" product?
Posted on Apr 28, 2013
  • 129 Answers
SOURCE: Moen Kitchen tap 87787 water pressure is extremely low
Yes it is very common more so on hot side, the water stops or shutoffs can become plugged with hard water deposits and calcium build up. Shut off main water, unscrew supply lines from shut offs under sink to see if this is indeed the problem.
Posted on Oct 04, 2009
  • 23 Answers
SOURCE: Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Posted on Oct 31, 2009
motor1258
  • 6674 Answers
SOURCE: my moen vestage faucet is dropping water pressure.
Have you removed aerator ,screen etc., from end of tap, to see how flow is with it off. If good, or same as other taps when taken off of them, then you've got debris in aerator, and screen.
Posted on Jan 03, 2010
  • 94 Answers
SOURCE: Have a Moen Anabelle faucet and the water is
could be as simple as your aerator is clogged,if not, pull your cartridge and check/replace
Posted on Apr 27, 2010
SOURCE: I have a Moen single
I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
Posted on Aug 19, 2010
I have a Moen bathroom sink faucet which just today isn't letting water through, or at a very low rate. Good pressure throughout the house elsewhere. It is a single control faucet, one year old
to valve is failing [need to replace the valve ]]or debris is stuck in valve either way would need to remove the valve body to inspect
Apr 20, 2017 | Moen Plumbing
We have a moen 7594E. Lower water pressure than old standard Moen.
The pull out spout/spray has backflow preventers built into the hot and cold supply lines coming from the body of the faucet. The backflows have a tendency to lower the flow rate because of the additional restriction they cause.
Mar 07, 2017 | Moen Plumbing
Moen kitchen faucet makes whinning noise
Water flow restriction of some sort is the only thing that can cause this.
Feb 22, 2017 | Moen Plumbing
Old Moen shower diverter
You will have to replace the shower diverter button. Remove the handle, remove the faceplate, and the diverter will screw out. Any plumbing supply that carries Moen products will have a replacement button for your valve
Feb 23, 2014 | Moen Home
We live in a house built in early 60's. Re; Plumbing to kitchen sink and dishwasher. On vary rare occasion the sink faucet will have decent water pressure. We have changed the water faucet with a Moen. As...
if this is the only place in the home where water pressure is a problem then the lines may very well be the issue. if you have low pressure throughout the home then there may be a problem with the main water supply in the home. if the lines are galvanized pipe then they may be restricted due to rust or other deposits forming on the inside of the pipe. unless you are good at plumbing then i would suggest having a professional come out and assess the condition of the lines.
Feb 25, 2011 | Microwave Ovens
I have a Moen single handle tub/shower faucet. I cannot yet get much pressure to the shower head, there is good pressure from the faucet. I have placed the shower head in vinegar with no improvement. ...
Your problem is in the water restrictor located inside the shower head. All plumbing manufacturers install these small plastic internal blockers to reduce water down to 2.5 gals per minute. In your case, this restrictor is most likely filled with sediment which is restricting it even further. Remove the shower head from the curved shower pipe. Look inside where the water goes through it. You should be able to see the restrictor. Maybe you can flush out the sediment. Otherwise, remove it and I'm sure you'll get more pressure then originally installed. Because most restrictors are sort of plastic screens or cones, I usually put a wood screw through the center of this product and then once a few threads bite in, I use a plyers on the head or the screw and pull outward while holding the shower head in a stable position. If you are able to get it out, technically your "out of code" because now your going to get all the water it can really supply.Most people are delighted to have it gone.
Nimsgame
Feb 14, 2011 | Moen & One Handle Tub & Shower Faucet
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Jan 31, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Low pressure,cleaned screen in tip,checked incoming supply,seems strong,yet pressure is low??
Has pressure always been low? If faucet is new than there will be a flow restricter in the aerator. Most flow restricters can be removed easily. Some are a pain. Have you tried checking the pressure with the aerator off. That would tell you if the problem is there or in the valve.
Apr 20, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Plumbing Logo
23 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
