Question about Exercise & Fitness
Horizon bsc 150 exercise bike will not reset resistance - pedal tension appears to be @ around 6+ setting and will not reduce
  • 31 Answers
SOURCE: The tension adjustment does not get difficult enough
If you are refering to a regular bicycle this means the derailer is not making the chain jump from gear to gear. You probably need a new shifter cable or the shifter cable came unhooked from the derailer. I would take your bike to a bike shop to have this reconnected and then they will adjust it for you.
If you are refering to an exercise bike then here may be your solution. From what I have seen on exercise bikes there are three different kind of bikes. I am refering to how there resistance works.
First type has a strap that wraps around the wheel. There is a some kind of a nut and a bolt that holds that strap around the wheel. You simply need to tighten that nut. The strap will stretch over time and that is why you do not have the same resisteace you had when the bike was new. Afer you tighten this you will find that regular tensioner works better.
The Second type of exercise bike has what appears to be brake pads contacting the wheel. Basically your peddaling the bike with the brakes on. Pretty simple concept. Again there should be some sort of adjustment around this pad that is touching the wheel. Probably a screw or a bolt. Some even have adjusters that you can turn with your fingers.
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. If changing the batteries doesn't help then there may be another problem. This could be the computer. Just check your user manual and I am sure you can get it replaced.
Posted on Mar 14, 2009
  • 31 Answers
SOURCE: The tension on the recumbent exercise bike does not get hard
If your bike has magnetic resistance and you changed the batteries this should make your tension work properly. Since it did not I believe that there are magnets somewhere on your bike that are wearing out. Or it could be a computer part. Your manual should tell what part you need to order and replace. I hope this information has been helpful.
Also make sure the batteries that you put in your bike are really new ones. Sometimes you can purchase new batteries at a store and they are actually a little weak. I had this problem with an elyptical trainer and I went and got other batteries and this fixed the problem.
Posted on Mar 16, 2009
OakRun
SOURCE: Wanted:Owners manual for DP Air gometer exercise bike
Scanned image of the 14 page manual that came with a DP AIR GOMETER Model 14-3800B that was purchased in 1991 is available at http://sites.google.com/site/oakrunsite/
Posted on Apr 12, 2009
protek480
  • 1714 Answers
SOURCE: voltage is high around 150 volts. I reduced the
The speed will change the 'frequency' too. You need to make sure you still have 60 Hz. You may have need a voltage regulator adjustment, not a speed adjustment.
Posted on Aug 01, 2009
  • 108 Answers
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Posted on Dec 07, 2009
Need replacement pedals for my resistant exercise bike
Rob, try any sporting goods that carry bicycles or bicycle repair shop for replacement pedals or order online.Check the attached links for replacement pedals. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VP Exercise Bike Replacement Pedals 1 2 Stationary Bicycle Pedal Set with...
Parts for Life Fitness Bikes Pedals Battery Pedal Straps SPORTSMITH net
Exercise Bike Pedals eBay
Apr 12, 2016 | Cycling
Recently assembled and tried bike. There seems to be a catch/hitch in the rotation when pedal at bottom. It should be smooth. What could be wrong and how to fix?
It's probably the bottom bracket bearing. Exercise bikes typically have really, really cheap bearings in them. I have the same problem on my Horizon M4 with a lot of bearing chatter when doing standing high resistance.
Mar 22, 2014 | Kettler Giro GT Programmable Cycling...
Resistance settings not working on fitnex r70 magnetic resistance exercise bike
If this is a new bike that may be the way it is. If it worked differently in the past, you may be looking at a busted tension motor or faulty brake.
Jan 03, 2014 | Champion Fitnex R70 Recumbent Exercise...
What are the different resistances on exercise bikes?
There are three main types of resistances, the fan resistance used to provide resistance with air they push as you pedal. The second type is the belt resistance which uses a belt that runs through a brake providing resistance for the exercise bikes. The third type is the magnetic exercise bike which provides resistance which can easily be adjusted while riding the bike.
Aug 09, 2012 | Exercise & Fitness
What is a mini exercise bike?
A miniexercise bike is a bike with pedals and resistance parts only. It has no handlebarsor seat. You can use it while you sit on a regular chair and you can move thepedals with your hands for arm exercise.
Jul 30, 2012 | Exercise & Fitness
TUNTURI E433 exercise bike--- can't change resistance
Hey roger,
I have buyed me a E430 but i have problem with it. does the bike work without the heart rate counter? I don't have it and the resistance is always changing in every program. So i like to know my bike is ok or not
Apr 13, 2010 | Tunturi E30 Ergonomic Exercise Bike
Hope this helps.
Richard.
Dec 07, 2009 | Cycling
Mar 14, 2009 | Cycling
Exercise & Fitness Logo
113 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
