Question about Cub Cadet Garden
I turn the key and nothing happens.
Put the battery back in the tractor yesterday and nothing happens when I turn the key. Put battery on my charger and it's all charged. Display does show in the dash panel, showing numbers and icon. Checked 3 fuses and they're OK. Not sure what else to check.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Check for corrosion runnig inside battery cable
Posted on Jun 07, 2014
  • 15 Answers
SOURCE: Tractor stopped running and now has no pwr at all. Does nothing
The problem requires a service tech. There are many reasons for the problem They can range from a battery that has gone bad to a relay or safety switch under the seat etc. Again the lever issue can be many things.
Posted on Apr 24, 2009
SOURCE: troy bilt zero turn
I have a zero turn Troy Built, It runs but the blades aren't engaging, I pull and push the pto button but nothing happens.
Posted on Aug 03, 2009
pumpkinman
  • 1147 Answers
SOURCE: Will not start. Nothing happens when the key is turned.
are you getting spark and or gas .i bet you check your fly wheel key itll fix it..they are known to partially shear ,giving you spark and gas but will not run.because when the key is sheared it throws the timing off.
Posted on Oct 04, 2009
  • 2239 Answers
SOURCE: Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
Posted on May 03, 2012
  • 7 Answers
SOURCE: Need Homelite Mower UT13122 wiring schematic to check switch problem. Battery fully charged
Check the switch for current flow with and without the key. Then make sure the ground switch is disengaging when you pull the handle.Possible stretched cable.
Posted on Dec 13, 2012
2004 Volvo XC70 won't unlock
Put a battery charger on the starter cable from
under the car & ground the black charger lead
That will charge it enough to open the door & hood
Thought every car has at least one key cylinder on
drivers door !!
Jul 08, 2013 | 2004 Volvo XC70
I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
My huawei ascend m860 wont charge. when i plug in the charger nothing happens. it was working fine yesterday and last night it wouldnt charge up. today i bought a new phone charger and it still wouldnt...
This happened to me too, you have to take your phone back to who you bought it from so they can repair it. Its the chip inside the phone that is bad. Not the charger.
Dec 31, 2010 | Cell Phones
Hello, my craftsman 13.5hp ohv rider will not start. The left front tire deflated here 1 week ago, so I left the mower in the back yard for 2 nights, which happened to be very cold with frost. After fixing...
Remove battery and bring inside. Let it set for a few hours to warm up, it may be partially frozen. If you have a battery charger, after it has warmed up fully, charge it at a slow rate (1A) overnight. Put it back in the mower and try again. If still nothing, the battery may be ruined.
Oct 09, 2010 | Craftsman 1 Bin Grass Bagger
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Jul 31, 2010 | Toshiba Video Cameras
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
Mower sat over the winter. Turn key and nothing
Neither ... charge the battery first. New doesnt necessarily mean fully charged.
Charge it with a properly sized charger for 24 hours then check with a volt ohm meter.
May 01, 2010 | Garden
I have a Craftsman 17hp....tractor was working fine til movers stored it then i attempted to start it at new house. Nothing happens when key is turned. doesnt turn over, no electrical power. checked...
Hey there,
Amps? Are you sure you weren't measuring voltage?
Either way the number is low indicating a depleted battery.
Try a jump. Just like you would a car with a dead battery. Be careful, it's a lot more cramped so take care to avoid a short. The result should be instantaneous. It's worked for me numerous times.
And it will not damage your tractor.
Best regards,
Mike
Aug 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
76 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
