Question about HTC Desire Cell Phone
Fail to mount/unmount device storage card. (1020)
2 Suggested Answers
SOURCE: will unmounting sd card erase photos on htc hero
Never
Posted on Mar 28, 2012
I have an Android ZTE N817 phone, and I want to know how to make my Sandisk Ultra Plus microSDXC memory card (64GB) my default storage. How do I do that?
in my zte phone the phone settings menu has a category labeled storage where you can mount, unmount sd card, get information on phone memory storage and sd card card storage volume used and volume available. It also has a button to select your default storage pathway, phone or sd card. Hope this helps you.
Aug 17, 2017 | ZTE Cell Phones
How do I mount my sd card
You will insert the SD card into the SD card slot on your device then you will power on the device and tap settings from the main menu click free format and then pick mount SD card when reformatting has completed.
May 04, 2016 | HP Computers & Internet
Files on SD card not appearing?
try to unmount your SD card from device storage settings from your phone and re mount it. Also make sure you are seating the SD card correctly, it could be that the SD card reader on the phone is damaged. However you can check this by inserting a different SD card and if that doesnt work. Its likely the SD card reader that has the problem.
Oct 15, 2015 | Android Apps
All of a sudden my dragon touch has lost all of the apps were on my sd card what can i do
Go to Settings>Storage>External SD and look for the *unmount* option. Touch *unmount*. This will electroncally close the SD Card connection so it can be safely removed from the slot. Then remove it from the slot. Then clean the brass contacts with a little piece of toilet paper. Then slide the SD card back into the slot.
The device should automatically *mount* the card. If it doesn't and there is a mount option shown then touch *mount*. If it still doesn't work then chances are your SD card went bad. They do that sometimes.
Jun 23, 2015 | Dragon Touch Tablets & eReaders
Says my sd card is unmounted or no files are on it. what happened to my files?
When you remove an SD card from its slot, you should *unmount* it first so you don't lose data. If you just pull it
out without first unmounting it, you could corrupt it and lose
data. This might have happened in your case or not. If you didn't remove it, try this.
Go to Settings>Storage>External SD, touch Unmount.
Then remove your SD card and using a Q-Tip and some
solvent like alcohol clean the copper contacts. Then slide it
back into the slot. The device should *Mount* it automatically.
If it still doesn't work, you could try hooking your device up to a computer via its USB cable and see if your computer can see any files on it. If it can't see any then somehow they could have gotten erased. Try loading them back. If they won't load and you get error messages, the SD card itself may have gone Kaput.
Apr 17, 2015 | PANDIGITAL Tablets & eReaders
How do l mount a sd card on my zeki tablet TBDG734B
Mounting is done automatically by the device in most
Android tablets.
For an Android, all you have to do is insert the SD card in the slot and it will be mounted automatically. If you want to remove the card, though, you need to *unmount* it. You can unmount in Settings>Storage>External SD card and will see the unmount option listed below it. Touch it and then you can remove your SD card without the possibility of corrupting the files.
Apr 17, 2015 | Tablets & eReaders
Having trouble with memory card for Samsung Note 2
the first thing i would try? move the apps back into phone memory out of the sd card.maybe put the wifi back on phone memory,shut the phone off,remove the battery,put it back in & restart phone.it may take a minute or two for the sd card to mount.
then to "my files" (under apps on home screen ).choose external memory.pick wifi,tap the top right button. you will see options.pick "move".pick "device storage".that should put it back on the device.turn wifi on & see if it works. (P.S-always before removing sd card,pick "storage" on your menu. you will see the option to
"unmount".be sure to do this every time before removing sd card.
Apr 03, 2015 | Samsung Galaxy Note 2
Camera says sd card unmounted wont work was working fine last night
In the settings menu under storage there is an option unmount sd card every time before removing the card from the phone or tab you should press this option unmount sd card otherwise directly removing the card without sectiong the option causes these errors
Oct 21, 2013 | T-Mobile Cell Phones
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
Dec 13, 2012 | Computers & Internet
I can't figure out how to get music from my computer to my new google phone
Before connecting the USB lead you must Un-mount the SD card in the phone. To do this you need to go to settings\sd card &phone storage\ unmount or eject sd card. Once this is done connect the USB lead and your computer should find new mass storage device and label it as an exrternal drive. Simply drag and drop your music into the music folder on the new drive.
Note: When youve finished you need to go back to the phone and mount the drive back on the phone following the same steps I described at the begging.
Hope this helps. Karl
Jan 10, 2009 | HTC G1
HTC Desire Cell Phone Logo
88 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
