Question about NRS Fleck 5600 - 64,000 Grain Timer Water Softener
Help setting DWC water softener - NRS Fleck 5600 - 64,000 Grain Timer Water Softener
I think when it come to soft water they are a waste of time and effort. The Tucson, AZ water supply may be low but it is tasty and free. Just avoid the hassle and mess.
Jason Stewart / www.watertectucson.com
Posted on Sep 06, 2013
Bypassing softener when watering the lawn. Uses too much salt..can we turn off the water softener when we are watering the lawn and how do we do this.
leave the setting on the water softener alone as it will become a tiresome exercise
place a "t" joiner in the water line before the softener with a tap on the outlet side to the softener and a tap on the outlet side to the lawn hose and fix your lawn hose to that
That way when you want to water the lawn adjust the taps so that the water softener is cut off and the hose is turned on
or when using the softener the tap is turned on and the hose is turned off
use ball valves ( 90 degree action)with a handle and the direction of the handle will determine the direction of water flow
Jun 19, 2016 | Dishwashers
I replaced old non working culligan system with whirlpool 48000 softner three months ago. In the mornings water from faucet has orange tint until run off for about ten minutes. Water feels soft in the...
Cabinet style water softeners (GE, Whirlpoool, Kenmore, Sears) are very inefficient at removing iron. They are not designed for water with high iron content such as yours. I might suggest setting the hardness level up as high as it can go (100gpg). Indications that water softener resin is getting fouled with iron are exactly as you described. Rusty water the day after a regeneration. You may need an iron filtration system before the softener so all the water softener has to do is remove the hardness.
Here is a link for an iron filtration system that works with air. Very simple, works very well.
http://www.water-right.com/residential/wholeHouseFiltration/impressionIronSulfur.php
RJH2O
Jun 19, 2014 | Whirlpool Water Dispensing & Filtration
Need owner's manual or set-up instruction manual for Pentaier Structural Water Softener - Model #CH30127
That is only the softener tank. We need to know what water softener valve you are using on the tank itself for further assistance.
RJ
Aug 19, 2013 | Pentair 14 x 65 Structural 30785 Poly...
WHERE IS OUR SOFT WATER!? A few years back we had the Culligan man out to check our water because it was not soft (at the time, we had the Culligan Mark 100 model). After testing our water, the suggested...
The most frequent causes for intermittent hard water would be the gallon settings set too low causing the softener to run out of capacity or a meter that is not measuring the gallons. I would set the "hardness" setting on your culligan softener 30% higher than actual hardness. The softening resins they use are low in crosslink and very inefficient. Also make sure there are no toilets leaking causing hard water to "bleed" through softener. Iron filters require regular maintenance to clear oxidized iron from nozzles and the valve. Generally it is better to have the iron filter regenerate at least every 3 days to keep the bed refreshed.
RJ
Mar 01, 2012 | Culligan Sediment Water Filter
MY GE WATER SOFTENER QUIT WORKING PROPERLY AFTER 6 MONTHS ,I HAVE HAD SERVICE CALLS AT $150 EACH TO NO AVAIL IT DRAWS SALT BRINE MY WATER HARDNESS IS 17 I HAVE SOFTENER SET TO 22 .I HAVE PRE WATER...
What is it doing? No soft water? What is the water analysis? Try manually regenerating 2x in same day. Make sure a bypass valve is NOT open. I need more info to help.
H2O Services
Jan 17, 2011 | GE 30000 Grain Water Softener GXSF30H
My Bosch Classixx dishwasher is using all the salt in one wash.Why and how do I resolve?
In order to rinse dishes and glasses satisfactorily, the dishwasher requires soft water, i.e. containing little or no lime, otherwise water stains will be left behind on crockery and glasses, etc. If the tap water exceeds a certain level of hardness, it must be softened, i.e. decalcified, so that it can be used in the dishwasher. his is achieved by adding a special salt to the water softener inside the dishwasher. The water softener, that is the required amount of salt, is set up according to how hard the tap water is.
Setting up the water softener
Determine the level of hardness of your tap water. Your local water company or service agent can help you with this. Identify setting from the following water hardness table.
Press and hold the B programme button, and set the main switch to ON, before releasing the programme button again.
The indicator lamp for the B button flashes, as does the figure in the numerical display. The latter represents the value that was preset in the factory.
To change the setting:
Press the B programme button.
Every time the button is pressed, the figure increases by one. After reaching 7 the display starts at 0 again.
Set the main switch OFF. The new setting is stored in the appliance’s memory.
Approx. 4 litres of water are required for regenerating the water softening system. The overall water consumption per load can therefore be increased by between 0 and a maximum of 4 litres according to the water hardness setting.
Oct 11, 2009 | Dishwashers
Manual
May I get the model # to help you more
Feb 12, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
I am so disgusted with my fisher and paykel washer!! It has ruined many of my clothing items due to fabric softener...what is the deal with this washing machine? I have had Fisher and Paykel washer and...
Are you using the fabric softener setting when using fabric softener? If not the washer is not using enough water to dialute and disperse the liquid fabric softener. a traditional machine uses about 45 gallons of water fisher&paykel uses 20 gallons. If you use liquid softener you have to use fabric softener setting and negate the water efficiency of the machine. I had F&P for a few years till I moved and there are tips but I really liked mine. Hope that helps.
Jan 11, 2009 | Washing Machines
NRS Fleck 5600 - 64,000 Grain Timer Water Softener Logo
149 people viewed this question
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
