I recently had to pull my Bosh out from under the counter to level it. Since I have placed it back under the counter (now level), the drain pump runs continously when the machine is on and the machine will not start a cycle. I found what I believe to be a float trigger for the basin underneath. When I activate that float, the pump sound changes, but continues to run. If I pour water into the machine, it discharges it without a problem, but the pump doesn't shut off. I pulled the door and slightly cocked it to one side on accident when moving it. When I closed the door, a small piece of plastic fell from one hinge point(right side.) The piece was not recognizeable. Is there some kind of switch I may have damaged?
-   I'm having the same problem, pump continually runs, though no water anywhere. Tried cutting power to the dishwasher, but no luck. As soon as the power button is pressed, pump runs again. Any solutions?-   curtis-r
Dec 26, 2007
-   I have the same problem works fine but after timer reaches 0 pump continues to run-   Guest
Nov 03, 2007
-   yes exactly the same problem with Westinghouse 906 any solution?-   Guest
Hi Display timer is incorrect resulting unit not working is there a way reset I had it service once...
(More)
Hi Display timer is incorrect resulting unit not working is there a way reset I had it service once prior and i believe it was some how reset
the door handle is loose, how do you take the soap dispenser off so you can seperate the door from...
(More)
the door handle is loose, how do you take the soap dispenser off so you can seperate the door from the inside panel
