Question about Retail Supplies
I'm looking for a ring display case
    New Friend:
  • 23 Answers
So many options. I reccommend to simply google the words: Rings Display Rack
See this for example: http://www.dhgate.com/wholesale/ring+display+stand.html
Posted on Apr 28, 2013
I have a display light lit up & I would like it off on my panansonic KX-DT343
Have you had a look in the menu and look for display backlight and set it to off that should solve that little problem.
Aug 27, 2014 | Panasonic KX DT343-B Digital phone - Black
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
My Maytag Ensignia washer is leaking water from the pump area of the washer. I've eliminated the drain hose and I've traced the leak up to the area of the plastic casing around what looks to be the...
Look for broken plastic casing of the pump. A hairline crack would also leak water. Check for proper fitting of flexible hoses to & from pump. Another thing is to check for loose filter cap. A loose filter cap or broken O ring of the filter cap can leak water.
Sep 18, 2011 | Washing Machines
Hello... i need a program in c...... a calendar where you can save on a specific date a reminder...
#include <stdio.h>
#include <conio.h>
#include <math.h>
#include <iostream.h>
#include <fstream.h>
int getdaycode(int year)
return(year+(year-1)/4-(year-1)/100+(year-1)/400)%7;
int bool getleapcode(int year)
return year%4==0&&year%100!=0''year%400==0;
main()
clrscr();
int choice,month,days,day,daycode;
printf("\t\t\tSCHEDULER-CALENDAR PROGRAM\n\n\n");
printf("Please choosefrom the Menu:\n");
printf("\t1- Calendar Dislplay\n");
printf("\t2- Schedule Editor\n");
printf("\nChoice: ");
scanf("%d",&choice);
if(choice==1)
clrscr();
int year;
printf("\tCalendar Display\n\n");
printf("Type the YEAR to be Displayed: ");
scanf("%d",&year);
printf("\nYear = %d",year);
bool leapcode;
daycode=getdaycode(year);
leapcode=getleapcode(year);
for(month=1;month<=12;month++)
switch(month)
case 1:
printf("\nJanuary");
days=31;
break;
case 2:
printf("\n\nFebruary");
if(leapcode)
days=29;
else
days=28;
break;
case 3:
printf("\n\nMarch");
days=31;
break;
case 4:
printf("\n\nApril");
days=30;
break;
case 5:
printf("\n\nMay");
days=31;
break;
case 6:
printf("\n\nJune");
days=30;
break;
case 7:
printf("\n\nJuly");
days=31;
break;
case 8:
printf("\n\nAugust");
days=30;
break;
case 9:
printf("\n\nSeptember");
days=31;
break;
case 10:
printf("\n\nOctober");
days=30;
break;
case 11:
printf("\n\nNovember");
days=31;
break;
case 12:
printf("\n\nDecember");
days=30;
break;
printf("\n\nSun Mon Tue Wed Thu Fri Sat\n");
for(day=1;day<=daycode*5;day++)
printf(" ");
for(day=1;day<=days;day++)
printf(" %d ",day);
if((day+daycode)%7>0)
printf(" ");
daycode=(daycode+days)%7;
if(choice==2)
printf("Schedule Editor\n\n");
FILE *fptr1;
char filename1[]="sched.txt";
int reval=SUCCESS;
if((fptr1==fopen(filename1,"w"))
printf("File cannot be opened\n");
reval=FAIL;
else
CharReadWrite(fptr1);
fclose(fptr1);
int
getch();
return 0;
Sep 07, 2011 | Computers & Internet
How do i change the ringtone callers hear when they contact my htc wildfire
Thanks for visiting FixYa!
In most cases, the ring tone callers hear (incoming ring tone) is controlled by your cellular service provider.
Try this first: (On the Internet) Sign-in to your cellular account. On your account page, look for a link that directs you to your incoming ring tones (or similar). There, you can change your incoming ring tone.
If you're unable to do that, contact your cellular provider's Customer Support. They can assist you in changing your incoming ring tone.
May 30, 2011 | HTC Wildfire Cell Phone
I have a 2008 jeep wrangler jk that burns oil. what is causing this
Most times that's caused by excessive wear of the piston rings or cylinder bores, valve guides & stem seals or even worn crank bearings. It's unusual to find one that young that has that kind of problem, but it can happen. I'd also check to make sure the engine venting isn't plugged up or it could be building excessive crank case pressure and pushing oil past the rings. No one can give you a definitive solution though without the benefit of some hands-on testing. I'd begin by checking venting and then do a compression test, after that, most everything else involves teardown and measuring.
Apr 24, 2011 | 2008 Jeep Wrangler
Where is the oil filter for a 2005 chevy cavalier located
ECOTec 2.4 Liter engine (and all ECOTec engine blocks in 4 cylinder sizes) have a cartridge type oil filter housing on the front of the block, driver's side of the vehicle.
The cap must be removed with a wrench, and the filter pulled out, then the new one put in. Now is usually a good time to replace the O-ring on the cap.
Dec 13, 2009 | 2005 Chevrolet Cavalier
On my phone system (M7310) I only want one phone to ring when calls come in. currently 2 ring. how do I turn the other off?
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Nov 10, 2009 | NorStar Meridian M7310 Phone
How to turn on the ringer
While the phone is not in use, press the up arrow until you get the ringer volume you want.
Jun 28, 2008 | Uniden Cordless Phone
Retail Supplies Logo
384 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
