Question about Irons
STRIPPING AND ASSEMBLING OF PANASONIC IRON NI-J1830B
NOT HEATING UP
5 Suggested Answers
oscarn
  • 109 Answers
SOURCE: My panasonic NI-R73NR iron went off and is not coming back on.
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Posted on Sep 21, 2007
jmgldsmth
  • 1889 Answers
SOURCE: Panasonic Iron won't heat
most iron cases can not be seperated from the iron plate but, if you can take off the bottom plate you will see a heating element and attached to that a small cylinder it has a point on one side and a flat end on the other it is called a thermal fuse and radioshack sells them
they are made in different versions so take the fuse in to get the right one clip it back in and your iron should work again
Posted on Apr 24, 2009
  • 13 Answers
SOURCE: Panasonic Iron NI-R73NR will not heat up
Either a bad thermostat or a bad heating element or an open connection somewhere in the power cord. My advice, toss it!
Posted on Aug 27, 2009
heatman101
  • 43501 Answers
SOURCE: Panasonic NIA56NR NI-A56NR Iron shut off and wont
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Not heating
try replacing the fuse that is located in the heating control panel area
hope that works email me and let me no if that works.tevin332000@yahoo.com
Aug 08, 2012 | Miele Rotary B890 Iron
No steam from a grime buster steam cleaner what is wrong?
Check the water reservoir for clogg. Be sure that the cleaner has water on it and it is heating. .If not heating there you'll sure it won't give steam. Check the heating element for open or no continuity.
Heated water needed to generate or produce steam and you'll need a continuity tester to test it. Replace it with similar model and rating also with same size.
Good luck.
Jul 07, 2011 | Irons
Iron getting power light on but not heating up and dripping water
I have a Breville Iron 2200W it went into auto shut down and now i can't get it to work
Jun 30, 2011 | Breville Irons
Iron has stopped heating
Check the power connection, the power cord to the heating coil. If there is no suppy then check the bimetal contact of the temperature setting switch, if voltage comes to coil without heating, the coil can be open .
You will have to use a multimeter in Ohms range to check the continuity of the coil.
Have to decide is coil is open about the cost of coil to that of a new iron.
Oct 05, 2010 | Euro-Pro Shark GI490 Iron
Not heating up
The connection to your iron is perfectly alright and also to the cut offf circuit but unfortunately there is either a failure of the heating coild of the iron or a link failure to the iron heating element. The last option to check will be take a continuity test with a multimeter, you must get a low range below100- 250 ohms reading. If not you will have to open and test the coil for continuity failing which the coild is open. Replacing the coil to the cost of a new irron must be checked out. Hope you work this out. Good day
Jul 26, 2010 | Sunbeam 4214 Iron
My iron will not heat when plugged into to the wall socket. Tried different places. Light comes on but won't heat. press to reset light stays on.
try opening the iron and see if the wires are connected to the thermostat/heating element, if not you can easily tie them again, it sometimes happens when the thermostat fails to open the circuit and the heating elements over heat and causes a break in the line or heating element.
Feb 07, 2010 | Oreck Cordless Speed JP8100CA Iron
My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Oct 02, 2009 | Irons
Iron is not fully heating
heatman101
Feb 21, 2009 | Rowenta DX6700 Iron
Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Dec 30, 2008 | Rowenta DX-8800 Iron
Irons Logo
64 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
