Question about Retail Supplies
Where can I find 2 layers long clothes rack? - Retail Supplies
    New Friend:
  • 23 Answers
Here are some examples for 2 layers clothing racks:
http://www.alibaba.com/countrysearch/CN/2-layer-clothes-rack-supplier.html
Posted on Apr 28, 2013
How to clean oven racks
If you mean the straight-in-a-line-parallel-stainless-steel-wire-rod type, we use these methods at home:
General all-round cleaning:
Oven-cleaner spray foam, left to soak to lift grease, then good sponge-down with water-damped cloth / sponge.
Stubborn gunk on racks:
Place racks in empty bath, spray/soak in oven cleaner, or..
pour or squirt engine cleaner / degreaser over entire rack surface, allow to work grease loose, then pour boiling hot water to rinse and dislodge fattiness and carbon.
Ordinary dry washing powder is high in caustic, so also works well.
'Handy-Andy' cream is quite high in ammonia among other unpronounceable chemicals for lifting stuck grease and oils.
Make a stiff, sticky paste of clothes-washing powder and water, then apply to a kitchen 'Zim', ie green scouring pad and mixed with lots of elbow-grease, can restore the racks to former glory.
Rinse well under running water to remove soap.
Otherwise 'bath' the racks in hottest geyser water with washing powder sprinkled on top to soak.
A stiff nylon brush helps to scrub the burnt bits away.
Dec 20, 2017 | Ovens
Remove wax on fabric
place one layer of greaseproof paper on the ironing board, several layers of absorbent paper such as disposable kitchen towel or tissue, then the fabric centring the wax then more absorbent layers and a layer of greaseproof paper - that protects the ironing board and the sole of the iron. Use dry heat, and press gently, gradually increasing the temperature of the iron until the wax melts and moves into the absorbent layers. Change the absorbent layers several times until there is no trace of the wax left in the fabric.
Apr 20, 2014 | Clothing
Wooden clothes rack shaky
Check the rods to see which are loose and add a tiny amount of wood glue if its possible. Remember put it in the hole where movement is not required for folding and putting away into storage. hope that helps.
Feb 21, 2014 | Honey Can Do Wooden Clothes Drying Rack
How are firefighters pants and coats made?
There are three layers built on top of eachother: a fire-resistant layer, a thermal barrier, and a moisture barrier layer.
Jan 13, 2013 | Work Safety
What are some different types of clothing racks for my store?
two way rack, 4 way rack, revolving belt rack, double bar rack, double rolling rack, collapsible garment rack, spiral rack, round racks, combination clothing racks.... there are lots of kinds
Jan 13, 2013 | Retail Supplies
GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Mar 24, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Uninstall Sharper Image Tie Rack from clothing rod
The tie rack just clips on in the middle. the small piece on the top of the bar in the middle of the rack slides to the left to uninstall, to the right to install. on the bottom middle of the rack is a round piece that tightens to hold the rack level. loosen that piece first, that the top middle piece should slide to the left.
Dec 30, 2009 | Kitchen Appliances - Others
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Retail Supplies Logo
373 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
