Question about Air Tools & Compressors
Movie Porter QR130
Looking for drivers to install OS into Movie Porter QR130.
How do I overhaul porter cable PN 100
Look on Google to see if anyone has posted instructions or a Youtube video.
Oct 04, 2014 | Porter Cable Tools & Hardware - Others
Cannot paly the movie xvid movie
Hi.First option: Check up your Device manager maybe your videocard driver not yet install.
Second option: need reinstall operating system and install all driver and this free software for all movies player. click this safe site to get free mpcstar http://www.mpcstar.com/
Jun 18, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My porter cable Finish Nailer 250B has a broken part. It is 119 by the parts list and Part number 904695. It looks like it does not come with gaskets/o rings. Is this something I can replace myself or...
You can reuse the oring from the old cylinder. Easy to install. The cylinder will break when the driver bends or breaks. If the driver looks good, dont worry about anything. Remove nails. Slip the driver into the cylinder and push driver and cylinder into body of the gun. Replace head.
Apr 29, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
I need web cam software
Try to post the model please
Dec 26, 2010 | Computers & Internet
MY SCREEN LOOKS LIKE THE MATRIX MOVIE. IT IS
The most probable cause is that your video driver is not up-to-date. Try updating your video drivers as soon as possible. You can download all the latest drivers (for Windows XP only) for your laptop from here.
Download all Drivers for Xp
For other Operating Systems, just search online for the drivers compatible for your laptop model mentioning the OS.
Dec 14, 2010 | HP Pavilion dv9000z Notebook
Nail is jammed in my porter cable fcn200 cleat nailer --how do I get it out?
It looks like those guns have a problem with driving the last few nails... so don't let them go all the way down before refilling...
There also should be a tool included to relase the nose so the jamm can be cleared...
Checkout the reviews here there is a ton of helpful info there...
http://www.amazon.com/Porter-Cable-FCN200-Pneumatic-Flooring-Nailer/product-reviews/B00005JRKG
heatman101
Nov 26, 2010 | Porter Cable 2" Flooring Cleat Nailer...
PIN100 leaves about a 1/8" of pin exposed every time.
I have seen many Porter Cable pin nailers with a bent or broken driver. Easy to check. With breakdown in hand (http://images.toolpartsdirect.com/schematics/portercable/pin100.big.pdf) remove head nut and other parts to gain access to piston/driver. (parts # 60084) Most drivers have the tip missing or driver is bent. Replace as needed. If driver looks good replace driver into cylinder and push all the way down. The driver should extend about 1/8" past nose. Check for obstruction around lower bumper. Parts are not expensice and are available at WWW.toolpartsdirect.com. Please email if you have any questions. Good luck.
Feb 16, 2009 | Porter Cable 23GA Pin Nailer Kit
"-36" error message using Acomdata External Hard Drive
Have you tried taking the files off of the drive and repartitioning and reformatting the drive?
How is the drive formatted? Fat? Fat32 or HPFS? What version of Mac OS are you running? It is possible, depending on the version of the OS and the driver for the OS that it can have problems with drives that have partitions larger than 128 GB. It is also a bios limitation with older systems.
Look to see if there is an updated driver for the OS X version you are running.
Also check in the Disk Utility to see how the drive is partitioned and formatted. If it is going to be a Mac only drive, partition and format it as HPFS. If it is a drive that you will use in Windows as well, use Fat 32 and limit the partitions to 128 GB or less.
You could also try a newer version of OS X like Tiger or Leopard. They are both more stable than older versions and have better support for devices.
Cheers and good luck.
Best
Dec 27, 2008 | Computers & Internet
Air Tools & Compressors Logo
76 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
