Labgear handylink 4 digital
Just moved 10 days ago in a flat which haslabgear handylink 4 digital, cable are : LNB in, UHF in, FMin connected with Sat, TV and FM dab, LNB output power on, then cables to output 1 and 2. Had received my sky HD box but no signal, the guy from sky couldn't fix it, first was no signal form satellite, now for less than 1 sec appears the channel number and what's on but no image then notice no signal. Phoned letting agency, sky, management company they are all doing nothing. Any thought how can I sort this out? As I'm a lady, please don't use abbreviation and will be very much appreciate if can be told which cable should be in which position either for labgear and tv/sat socket. many thanks
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
  • 3 Answers
SOURCE: LG 47" 47LG50
Most likely it is not the TV; it's a grounding problem. Are all your devices plugged into the same power strip? They should be. Can you plug that power strip in to another outlet in the wall (even with an extension cord, just for testing purposes)? If that removes the lines, leave it plugged in there. If you can't leave it plugged in there, you'll need an isolator like the Jensen VRD-1FF or similar.
Hope this helps!
Posted on Jun 12, 2008
SOURCE: TV not finding Digital Channels from Cable Box
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
Posted on Aug 24, 2008
  • 189 Answers
SOURCE: how do i fit a dual LNB so i can change channels
HELLO
A word of warning! Do not attempt to split any feed coming from a single output LNB to another satellite box - you will be asking for trouble!
Now for the solution. If you are using a standard sky minidish you will need a 40mm adaptor kit, a dual output LNB and another length of satellite cable (Webro WF100 prefereably) but I suppose RG-6 will do the job providing it is not too long (around 10-15 meters or so) a couple of F connectors and self-amalgamating rubber tape.
Power off everything! Remove the old LNB and to do this you'll notice a plastic rivet on the LNB arm of the dish which must be removed. When you have done that and the new LNB is place (don't tighten everything yet), connect your current length of cable to one output and the new length to the other (finger tight should be fine) and make sure BOTH of your boxes are connected. Remember to waterproof those LNB connections.
Power on! You should be getting pictures - if not the LNB will need skewing round a bit. Look at the dish from the front and turn the LNB in a clockwise position say the 2 o'clock position - that should do the trick. Then tighten everything.
I wish you well with it - good luck! (:-)
Posted on Sep 20, 2009
Testimonial: "Thankyou Tony,most helpful Best Regards Rob Allen"
What is the video single output VHF FM UHF 12db
That sounds like the description of a broadband amplifier. It likely has "F" type (cable-coax) connectors and a power cord.
Commonly used to increase the signal level of TV cable to compensate for inserting a signal splitter, or in some cases to increase the signal level from an antenna, typically outdoor TV or FM radio antenna, so it is connected between the signal source (antenna, or cable) and receiver with antenna as input and receiver connected to the output of this little box. The gain (amplification) it provides is 12 dB, so the output is more than 3 times the input.
Oct 03, 2014 | Radio Communications
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Dish 625 with legacy lnb
Hi beltone669,
Our 625 receiver uses DP technology. A legacy LNB would not work with the receiver. You would need either a DP Dual or a DPP Twin. If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Mar 31, 2012 | DISH Network DVR-625 DTV Receiver /...
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
I have a 46 Samsung and when I turn on the TV I get sound but no picture. I get tv menus, sat menus, and dvd's work but no picture on sat.
The problem of your tv is only the connection or the digital receiver. Try to check the cables that are connected in your tv specially the input,output of the digital receiver or use another cable for the video in of your tv if still no picture try to contact your satellite service provider the unit is may be defective. good day and hope that it may help thank's.
Jul 14, 2011 | Samsung LN-T4665F 46 in. LCD Television
Dvdr3320v will this model record digital tv programs
This device has 2 composite AV, 1 S-Video, 1 Firewire, 1 RF video inputs. The RF input is a way for it to accept a signal from say a VCR's or Video Game's output on Ch 3 or 4.
Your device also can record via internal tuner.. The tuner can tune VHF:2-13, Cable:1-125 and UHF:14-69. Unfortunately, if you only have a UHF / VHF antenna on your house for TV (do not have cable TV, satellite TV, or the like) you're not going to be able to find anything due to the change from analog TV to digital TV. For this, you would need to purchase a digital TV converter box, and put the output of it into the the DVDR3320V.
I hope this helps and good luck. Please rate my reply. Thanks.
May 06, 2011 | Philips Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
How do I conect external radio/speakers to my lg 42lh40-ua
There are many options here. Most HDTVs today have analog audio and digital audio output jacks. You can use RCA audio cables or a 3.5mm connector, whichever your HDTV has to connect the analog stereo output of the TV to any number of devices such as a stereo/amp which has speakers attached. You could also connect an FM transmitter to the TV and send the audio wirelessly to a nearby FM radio, boombox, portable etc. Most HDTVs today have a digital audio output, typically optical, which uses a digital audio cable ($15) to connect to a surround sound receiver. You can also connect the stereo analog output jack on the TV to a 2.4GHz transmitter and receiver speaker combo to get wireless audio outside, in a swimming pool and so forth, all around the house using wireless speakers. These setups usually cost around $150 or so. Look for the jack on the TV labeled AUDIO OUT and see if it is the white and red 2 jack ports or the smaller 3.5mm single jack port. Adapter cables are available at Radio Shack for around $10 should you need them. So you see the options are almost endless.
Aug 17, 2010 | LG 42LH40 LCD TV
I disconnected the 322 to install a new TV1. TV2
You should have one line entering the home behind the TV1 attached to it there should be a device exactly as you saw outside. You will want the line from outside connected to the single port called in/out and the SAT port goes to the silver seperator. The two lines leaving the seperator attach to the SAT in on the receiver. The UHF poret on the device connects to the home distibution port on the receiver.
Thanks for using Fix YA.
Feb 09, 2010 | DISH Network 322 DTV Receiver
How do i fit a dual LNB so i can change channels
HELLO
Sep 20, 2009 | Televison & Video
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
