My msi is fx620dx eject key doesnt work.what shall i do?thanks
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
SEE SIR THIER COULD BE MANY REASONS FOR IT
1. FAULT WITH OPERATIONG SYSTEM
FOR THIS PURPOSE YOU CAN SYSTEM RESTORE YOUR PC ACCORDING TO THE DATE YOU ARE FACING PROBLEM
(SYSTEM RESTORE RESTORES YOUR SYSTEM SETTINGS TO PREVIOUS DATE WHEN IT WAS WORKING FINE)
STEPS
1. GO TO START
2.ALL PROGRAMS
3.ACCESSORIES
4.SYATEM TOOLS
5. SYSTEM RESTORE
6. RESTORE MY COMPUTER TO AN EARLIER TIME
7. SELECT THE DATE ACCORDING TO THE TROUBLE YOU ARE FACING FROM ()YOU WILL NOT BE ABLE TO SELECT ALL DATES THICKER LETTERS ONE CAN BE SELECTED AS THEY CONTAIN CHECK POINTS)
8. RESTORE
NOTE:
YOUR SYSTEM WILL BE RESTARTED AND SETTINGS WILL BE SHIFTED TO EARLIER TIME BUT BACK UP YOUR OS DRIVE THAT IS C,DESKTOP, MY DOCUMENTS E.T.C LOCATION FOR IMPORTANT THINGS BEFORE DING THIS SOME TIMES MIGHT BE RISY
AND IF STILL THE PROBLEM EXITS EITHER SEE BY FORMATING OR SIMPLY TEST WITH OTHER USB KEYBOARD IF ESC BUTTON WORKS ON USB KEY BOARD THEN
2. CHANGE THE KEY PAD
Posted on Apr 28, 2013
Fn doesnt work
You might try an external keyboard to reset your configuration settings.
Mar 09, 2014 | MSI Computers & Internet
Fn key doesnt work
The Fn key on laptops is only used in conjunction with other keys.
look at your KB you should see some icons that are the same colour as the Fn key eg on my laptop the F5 key has 2 TV symbols, this pressed while holding the Fn key turns on the external display port, perfect for connecting to a projector, other combinations are for turning WiFi off and on, mute, volume control and brightness.
Mar 09, 2014 | MSI Notebook CX640071US 156inch GT520M...
My MSI GT70 isnt working his Quick Launch Buttons (eject button and turn off the screen button). What i can do?
Most likely a hardware problem as software problems of well tested programs do not fail.
I suggest you take your laptop to the shop where you bought the laptop and get it repaired or replaced under warranty.
Jan 07, 2013 | MSI GT70 0ND-202US 17.3" Full HD LED...
2008 Hyundai Elantra. CD is stuck in the player. Says "Loading'. Can't eject it. Radio works fine. But CD is hopelessly still loading and stuck. Is there a pin hole eject or an easy way to...
disconnect the 2 audio fuses and wiat 5 minutes with the ignition key off, insert both fuses, then turn the key on. if it doesnt eject, it probably has an internal defect and will need to be repaired.
Jul 25, 2011 | 2008 Hyundai Elantra
Door will not open
make sure the drive is not reading a disk, because if its spinning it can break when you do this process.
look for a hole in the front of the drive, get a paper clip and stick it in there all the way, the tray will now eject or if its a slot loading drive the cd will eject
Sep 06, 2010 | Computers & Internet
The touchpad of my msi pr400x stopped functioning
You should makes sure you have the touchpad enabled. This is usually Fn F5 or whatever key is assigned to the touchpad. This is indicated on the F1-12 keys by a little blue icon. Hold the Fn key, and hit the corresponding key. Check to see if it turns back on. If the touchpad still doesnt work, you've got a hardware problem.
Oct 19, 2009 | Computers & Internet
The mouse pad on my new acer travelmate 4730 doesnt work
Hold down the function key (Fn) then press the F7 key. This is keyboard shortcut to toggle on and off the touchpad.
Sep 04, 2009 | MSI M510C Notebook
Can't access BIOS
Eject and re-insert the bios battery.
Aug 30, 2009 | Intel Motherboard
CD tray doesn't open
ok there is a small hole below the tray, use a small paper clip
wire to push in that whole, push and the tray should come out.
if that doesnt work take cd player out, push plastic clips on side
and top at front , front plate should come off .
where small whole was in front look behind plate you will see a small little metal arm push on that
should be able to clear cd player then .
Jan 27, 2008 | MSI (MS-P8148-050) (MSP8148050) CD-ROM...
What shall i do...
you could try here for the driver http://driverstock.com/download-Epox-5VKMI-driver/26-9-1982/index.html
riz.
Nov 05, 2007 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
