Question about Syma New Green S107g 3 Channel Rc Radio Remote Control Helicopter With Gyro
My gyro s107g helicopter will not levitate - Syma New Green S107g 3 Channel Rc Radio Remote Control Helicopter With Gyro
    New Friend:
    Problem Solver:
  • 13 Answers
Press the left button(LB(like on xbox controller spot))
Posted on Jun 27, 2013
My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
Remote not working
I would suspect a fault but check the batteries in the remote are fitted
correctly.
Jan 28, 2014 | Syma GIFT SET 2 S107G R/C Helicopters Blue...
Helicopter not stable
Hi, I had a toilet bowl effect after changing the blades on my s107g. After making sure the shaft was seated properly, I simply adjusted the tension on the screws holding the blades in position and after a bit of trial and error tightening and loosening: it's as good as new!
Jan 21, 2013 | SYMA Toys industrial New Syma S107 Radio...
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
Will not levitate in air
FIrst read manual for all the instructions, if that dosen't work then it could be faulty.
Oct 14, 2012 | Syma 107 S107 S107g Metal 3ch Gyro...
My S107G Metal Series will not take off just sits and spins how can i fix
If there are two blades that turn in opposite directions, perhaps the blades are reversed. If that is the case then they are pushing the helicopter down instead of up.
Sep 09, 2012 | SYMA Toys industrial New Syma S107 Mini...
Inferred controller loses contact with the S107G
Moving to solution section so more people will see it:
Infrared is different band of electromagnetic spectrum from radio and is subject to the same problems as radio waves, namely, noise, transmitter problems, and receiver problems. the receiving antenna will not be a wire, it will be a infrared photocell. The sending "antenna" will be an LED.
A few things to try..
- make sure that nothing is covered on your handset and the helicopter that did not come that way
- Switch channels
- try a different location to see if anything in the environment is interfering, it could be something generating a lot of heat (including bright lights or sunlight) or another infrared device, like a remote control or some wireless devices like headphones and 3D video game systems with active shutter glasses.
- turn everything else off where you are trying to fly - might have to unplug electronics and remove batteries from remotes to make sure they are not emitting
- try linking a different helicopter or different controller that you know works to see if it is on one or the other of yours
I tried putting my hand over the emitter and the helicopter, and could not block the signal. I flew mine to the balcony out of site, and it still responded fine, so the signals bounce around enough quite a bit.
Jan 05, 2012 | SYMA Toys industrial New Syma S107 Mini...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Syma New Green S107g 3 Channel Rc Radio Remote Control Helicopter With Gyro Logo
387 people viewed this question
Top Syma Video Game Consoles & Games Experts
Gil Shultz
Bill Boyd
John mullen
Are you a Syma Video Game Console and Game Expert? Answer questions, earn points and help others
