Question about ASUS Q200e Touchscreen Notebook
I opened and started my laptop for first time on 26th April 2013, after initial settings and windows activation on same date,the battery was shown low by laptop,so I plugged charger. Now,as I am charging battery,I feel mild electric shock waves all over the metallic part of laptop including lid and interiors,while moving fingers over. Moreover,while charging,the track pad does not respond well,the cursor hangs and sometimes uncontrolled movement,but only during charging it is happening.Also I hear a constant 'kit-kit' kind of sound repeated within interval of few seconds present even without charging position. So I am afraid to use it furthur.Can anybody help ? Thanks in advance.
    Habit-Forming:
    New Friend:
  • 38 Answers
Are you using a 2-pin plug?
Usually when you use the 2 pin plug, there is no earthing/grounding available so the current passes through your body to the ground.
Try using the 3 pin plug. It should solve the problem.
In case it doesn't, it's better to get your laptop checked.
You can buy a 3-pin plug laptop charger at
http://memory4less.com/adapters-and-accessories
Posted on Mar 29, 2017
LavaTech
  • 22 Answers
SOURCE: can i fix my broken laptop.
Well, if the display comes on at all, then it must be a loose connection in the wiring. Sometimes this is a simple reseating of the main cable to the mother board which comes down from the display near or around one of the hinges (in most cases). I would suggest, purchasing a cheap external monitor, and plugging it into the rear or video out port if you have one, and switching your display to go to the external monitor, this will work good as a desktop scenario. Otherwise, you need to take it all apart and see if you can find out where the loose connection is, this is no easy task, and should be done by a qualified laptop repair person who has experience.
Posted on Mar 23, 2009
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Posted on Jul 19, 2009
  • 60 Answers
SOURCE: initial trouble charging EEE
Try taking out and putting back in battery. also check to see if contacts on battery has tape on them.
Posted on Jul 23, 2009
SOURCE: Hi! i have an Asus
Hi there, I had and have the same problem since I bought.It went to Asus to repair and 1º time, 1 month later, they said it was a fault in the camera, and replaced it. Bah!! the 2º, 3 month later, it was the OS and reinstall it the XP. Bah!! bullS" the 3º time they update the BIOS which worked until now, but the reality is that it was just a lucky, it is for sure the BIOS or chipset problem. Mine occurs when I am running on battery and with the WIFI and Bluetooth on and the battery runs out, either the XP tries to hibernate or suspend mode and after that it show the same problem as you describe. - I know it does help you but it might give more hints for who understands.
Posted on Oct 31, 2010
Rider On Way
  • 1679 Answers
SOURCE: cursor on screen is frozen, cursor moves with pad
Which make is this laptop ? is it Dell or HP etc ?
Posted on Mar 01, 2011
Electric current shock
If you have just purchased this laptop then return it to the shop and ask for a warranty replacement. Do not try to repair it yourself as you may void your warranty.
Apr 28, 2013 | ASUS Computers & Internet
F8 will not stop xp from starting up fujitsu lifebook
When you install Windows you are given a a set period of time to Activate your Windows operating system. Failure to do so after the expiry date Windows will stop operating.
You will need to reinstall Windows so you can then Activate Windows before the expiry period.
Feb 17, 2013 | Fujitsu Siemens Computers & Internet
Some of the keys give different letters to those shown
It sounds like the Keyboard Language Setting is not set correctly.
Open Control Panel from the Start Menu (may be under settings) then look for Date, Time, Language and Regional Options. Within that, select Regional and Language Options. On the Languages tab, click the Details button.
Verify that the correct Language is shown in the "Installed Services" box, and also make sure that the Default Input Language dropdown (above) is set correctly. You can use the Add button to add a new language that isn't already shown.
These instructions are for Windows XP with the control panel set to Category View. If you have a different version of Windows please post further details.
Feb 02, 2011 | Advent 4211c Notebook
How to change the date
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month shown.
The Day blinks. Press Setting until the correct day is shown. Press Select to set the day
shown.
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
Press Setting to choose one of the following Print Methods.
The TC100 has two settings for print activation: Manual or Automatic
1 = Automatic (default setting) - The TC100 automatically prints when the time
card is inserted.
2 = Manual - After inserting the time card, press the Print Button to activate
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational.
Dec 20, 2010 | The Times ROYAL TC100 TimeMaster Time...
Thinkpad R40 find date & time for start-up
Right-click the time in the lower right, select: adjust date and time, select: internet time, select either source, select: apply (if high lighted)--otherwise close. You need to be connected to the internet for the internet time to work.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Time/date never stay set.f1 f2 f3 always there on start up
This sounds like the cmos battery is low.
This battery sits on your motherboard and provides the ROM with energy. Replace this small battery, set date and time a final time and then it won´t happen again.
May 28, 2009 | Computers & Internet
Information about virus.
The CIH virus infects executable files and is spread by executing an infected file. Since many files are executed during normal use of a computer, the CIH virus can infect many files quickly.
There are several variants of the CIH virus. Some activate every month on the 26th, while other variants activate just on April 26th or June 26th. Once the CIH virus activates, the virus attempts to erase the entire hard drive and to overwrite the system BIOS. Some machines may require a new BIOS chip to recover if overwritten by the CIH virus. CIH only affects Win95/98 machines.
More technical details about the CIH virus can be found at the following site.
Go here for more information
http://www.cert.org/incident_notes/IN-99-03.html
Hope this is some good knowledge base for your project.
http://www.virusbtn.com/VirusInformation/cih.html
May 26, 2009 | Computer Security Systems CSS-A760S...
Time and Date Setting
There is a lithium battery in your computer that needs to be replaced. If you open up your coumputer, look for a round looking battery about the size of nickel.
Jun 30, 2008 | Microsoft Windows XP Professional With...
Daylight savings time adjustment
Go to:
http://www.emersonelectronics.ca/emerson/en/product/details/VLJT600
or
http://www.emersonelectronics.ca/emerson/en/category/list/694
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source: http://webexhibits.org/daylightsaving/e.html
Oct 28, 2007 | Emerson CKS3029 Clock Radio
ASUS Q200e Touchscreen Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
