Question about Canon Pixma MX410 All-In-One Printer
The printer's lying to me
My canon won't let me print, I've changed my black ink cartridge (the colour one is empty and not needed.)Due to the empty colour cartridge the printer will not let me print my black and white document, this has never happened before. Help!
  • Canon Master
  • 1,684 Answers
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Posted on Apr 30, 2013
  • 37 Answers
SOURCE: PIXMA iP6220D doesn't use/recognize CL-51 cartridge
Take the photo ink out.
Posted on Aug 19, 2008
  • 62 Answers
SOURCE: Print WITHOUT colour cartridge
If you right click the printer in the Printers section of the control panel and select printer preferences, there should be a tab called maintenance. In this tab, you should find a setting called Ink Cartridge Settings. Once you click on this setting, click black cartridge only. This should allow the printer to only use the black ink and therefore you won't need color.
If you have any other questions or this doesn't solve your issue, let me know.
Posted on Jan 10, 2009
  • 739 Answers
SOURCE: Canon MP600 printer. Black Ink cartridge PGBK5 is
You need both. One is pigment and the other is dye. One is used for photographs and the other for non-photographs - but it's the printer that decides which one to use.
All Canon printers (to my knowledge) will stop working if any one ink cartridge is empty. This is to prevent damage to the print nozzles. The ink itself is the cooling medium for the hot nozzles.
Posted on Nov 29, 2009
Testimonial: "Instant answer so I can stop trawling the internet now! Thanks"
  • 164 Answers
SOURCE: black cartridge emptied half way
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most walmart pharmacy departments.
*Warning: You may want to usea pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Patience
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent aeound it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, slternately sloshing/swishing and pouring solvent over head (be carefull not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY,with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
  • 328 Answers
SOURCE: The black print won't print, but colour does,
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
Posted on May 27, 2011
Canon Pixma 5100, no black ink, but blue won't print? why?
Main Cartridge is black it is required for printing it is not possible to print black with other cartridge.
Jan 02, 2013 | Office Equipment & Supplies
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
The black print won't print, but colour does, although very lightly. I have refilled the ink cartridges at Island Inkjet, so there is ink,..but black won't print at all.
May 27, 2011 | Canon PIXMA MP610 InkJet Printer
Canon ip4300 color ink empty but I only want black
No, Canon does not have this facility. Also mostly greyscale is not light black but rather a mixcture of the 3 primary colours. You should have a reset/resume button on the printer - hold this in for a slow 5 seconds to de-activate ink warnings per cartridge that is giving alarms. Proceed carefully and only print text that is black so that the colour printheads do not burn out.
Feb 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Canon Pixma MX410 All-In-One Printer Logo
237 people viewed this question
old marine
old marine
