Question about Philips Televison & Video
Dlp light engine replacement - Philips Televison & Video
    Top Expert:
  • Philips Master
  • 74,106 Answers
Actually it is a semi-skilled work. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. After replacement, you have to enter its service mode option to reset lamp time. All details are described by a post there. http://electronicshelponline.blogspot.com/
Posted on Apr 29, 2013
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Televison & Video
How to install toshiba dlp light chip
This is a part of folk lore, the DLP display "chip" is not available from the company who made this (or for that matter any other brand) and even if it was you would need the $1,000 plus desoldering station to attempt its replacement.
What is your problem? dots? if that is it the answer is either buy a optical light engine or buy a new set.
Nov 26, 2011 | Toshiba 65HM167 65" Projection Television
We are having white dots appearing on our Mitsubishi DLP 65 inch television, approx. 3 years old. It looks like a constellation is appearing. New dot every day.
That means you need to replace the Optical Unit Block/Light Engine.Dmd board has been known to cause this also, but most of the companys replace Dmd and optical unit.
PTS rebuilts Light Engines 1-800-844-7871
Encompass Parts Distribution List this Model /Parts 1-800-638-3328
Jun 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Our 55" Samsung DLP television has white dots all over the screen. Day after day, more seems to appear.
The DLP tv projection light engine is the cause.This problems,very expensive to repair or replaced the projection light engine.Samsung know about this flaw in the tv design.Talk to them,make a deal with them about it.Help u repair it.
Sep 27, 2010 | Samsung HL-T5676S Television
I have white specks on screen toshiba 65 in DLP
White dots on a DLP mean that some of the tiny mirrors on the DMD board have failed and are stuck in the on posisiton and always reflecting the white light from the lamp. The DMD on this model is not available sepratley so the complete light engine needs to be replaced. The part number for the light engine is 75006693.
Aug 28, 2010 | Toshiba 65HM167 65" Projection Television
White spots on samsung DLP tv
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Apr 27, 2010 | Samsung HL-R4264W 42" DLP HDTV
Samsung HL-S4266W 42 in. TV has a bad DLP module. Specifically, an increasing number of bright white dots are appearing on the screen. What's the part number for a replacement module, and where can I buy...
The part # all depends on which version of the set that you have. Take a gander round the side of your side. Right side, if memory serves. You should see a sticker with 3 lines. One for model #, one for serial and one for version.
On the off chance you don't see one, check around the left side of the screen and take note of the lamp code. Your version will probably be a PB01 or PB02.
Depending on the version, the part # changes. Either way, you're looking at about $200.00 for a DLP chip. That's just the chip mind you, not the DMD PCB that drives it, or the rest of the light engine that helps process that information. I have had, during the course of my career, replaced a DLP chip to address white spots on the screen and found that insufficient voltage from the power supply cause the issue in the first place, or that the light engine itself was a contributing factor.
If you were to replace the light engine itself, you would replace all three components here and guarantee yourself a solid repair. You would hit the LE, the DLP and DMD all at once by doing a light engine. Granted, the cost is substantially more, but it might be easier in the long run to swallow $600.00 for a completed set than to swallow $200.00 for a DLP chip that didn't fix the issue and now can't be returned. Plus, a light engine will literally take you 30 minutes to put in and be done. Maybe even less.
PS - Don't touch the surface of that chip. And when you remove the DMD, pull out the old DLP chip and insert the new one....you're going to have to have help. Someone is going to need to watch the screen while you manipulate the DMD--set on and running--to align it back to the aperture. Have fun.
Part #s: Version PB01 :
4719-001968
Version PB02:
4719-001981
Try partstore.com to secure parts.
Jan 22, 2010 | Samsung HL-S4266W 42" HDTV
Need to replace light engine on a toshiba 56 DLP
try this link it's arrowed $270
http://www.discount-merchant.com/TOSHIBA-4D09-40A-Light-Engine-w-Color-Wheel-p/1130472.htm
is like this depending on your Tv Model
Nov 24, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Speckles in dlp tv screen samsung 50" dlp
No they couldn't have replaced everything or did they Replace Light Engine? Because that is what is Bad on your TV if under warranty get it Fixed Now Light Engine is very COSTLY !!!!!!!!
Sep 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Spots on screen
Spots on screen do not automatically mean you need to replace the light engine. It depends on the brand. Panasonics can reset the eeprom. Samsung can replace the DLP chip. Hitachi needs a light engine replaced.
Nov 26, 2008 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
