Question about Frigidaire Refrigerators
FRT17B3AW3 Ice maker kit for this model
Gigatech
  • 259 Answers
SOURCE: Installing Ice Maker kit
Here is some helpful links on installing icemaker water lines. Hope this helps! :]
http://www.diynetwork.com/diy/ha_installation/article/0,,DIY_13868_2268470,00.htm
http://www.hammerzone.com/archives/plumbing/refrig/icemaker.htm
Posted on Dec 09, 2007
Maytag317
  • 1136 Answers
SOURCE: Ice maker water line freezes
Hi, it sounds like the water valve is leaking just enough to cause the water to freeze in the inlet tube. This is the most common fix.
If I can assist you further, please let me know.
Thanks
Vic
Posted on May 15, 2009
hiltonjug
  • 612 Answers
SOURCE: Recently (last week) purchased a KBRA22KSMM,need ice maker kit
I researched this for you in my data base. Man, this is a new unit. It suggested to use a IC13B.kit. The best price I found is at http://www.hhgregg.com/ProductDetail.asp?productId=23004 they are asking $59.97 plus shipping or if there is a hhgreg around, you can save shipping but will then pay tax. This is a brand new kit and I have not seen one of these yet. From what information I can find, it does come with every thing you will need to install in your unit.
Just a reminder.
Don't forget the water supply. If your replacing a fridge that had a ice maker or water in door. you will already have a supply. If you are going to have to run one, I suggest that you spend the extra few dollars and get the copper rather than the vinyl set. Good luck.
Posted on Oct 19, 2009
Testimonial: "Great information and fast"
  • 20 Answers
SOURCE: ice maker bar keeps falling out
if you are putting it back on right...and it keeps falling off, get a new icemaker
Posted on Nov 12, 2009
SOURCE: ice maker not putting out water just hooked up ice maker kit
Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
Posted on Jul 06, 2010
Wire harness on ice maker kit does not fit
New ice maker should have came with a replacement harness if this head fits multiple frigs, if this is a direct replacement and harness dose not match the other end then suppler may have gave you wrong part.
May 11, 2014 | Whirlpool ECKMFEZ1 Ice Maker Kit
Model 106.57036601 Ice maker quit working couple days ago had water off in whole house, had to repair a water pipe in the restroom.
There are a couple or three ways to test your ice maker and dual water control valve to identify the location of the problem. By looking at what the ice maker did on its last cycle or the lack of a cycle will help a lot. If ice maker has old cubes then the ice maker has not cycled and that tells me that the ice maker has been turned off or it has become defective. Another test is to pour tap water into the empty slots if there was not old cubes there. Allow the water to freeze and if the ice maker cycles and dumps the cubes into the ice container that would indicate a defective dual water valve=> 4389177 Water Valve Kit- Double Outlet The first three numbers of your model tells me it was made by Whirlpool and that tells me that removal of the front cover of ice maker you have test points. If me knowing what I know of ice makers I would be prepared to change both ice maker core=> 2198597 Ice maker - Replacement
Below is a short You-Tube ice maker help tutorial by the Appliance Assistant that can be very helpful. Should you have questions please ask, Thanks, Sea Breeze
Jun 10, 2011 | Kenmore 56733 Side by Side Refrigerator
Woodchuck told someone that the flakes coming out of their ice could be the ice mold coming apart. That's the problem I have. Pieces of that mold are flaking off. Do I have to replace that part? What is it...
Replace the complete ice maker . Less hassle and maybe $ 125. total . Only 2 or 3 screws hold the ice maker in place . If you have a side by side , buy the kit for your model . Usually kits are less expensive than buying the ice maker by itself , even though you only use the ice maker out of the kit .
Mar 30, 2011 | Refrigerators
Magic Chef refrigerator model CTF1923. erratic ice production
As long as your freezer temperature is at 0 you should have steady ice production. If you have to jumper the ice maker to get it to harvest then you most likely have a bad thermostat. That coupled with the leak issue really warrants just replacing the entire ice maker.
Be sure to ask for pricing on both the ice maker by itself as well as the complete kit. You may be surprised to find that the entire kit (including a new valve, line and bucket) will cost lest than just the ice maker by itself.
Jun 13, 2010 | Refrigerators
I have a whirlpool refrigerator . When the refrigerator completes its cooling cycle the motor and tray shakes and bangs the refrigerator. Can you tell me how to solve this problem Model # BT18NKXYWO1,...
I could not make the model number work but on them older model ice boxs they used the ice maker to do the defrosting. Remove the ice maker and the icebox is dead in the water. You can buy a module88d38c4.jpg that replaces that ice maker for much less than a new ice maker. You can also buy a gear kit (978138) for that ice maker but you may not have any success in rebuilding it. It is kinda complicated.
Apr 19, 2010 | Refrigerators
Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Jun 11, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Our FRIGIDAIRE refrigerator doesn't defrost properly or could be a problem we aren't aware of. We have water lying on bottom shelf and below bins. We have used towels to absorb water but that becomes...
this is a fairly simple fix.your drain is clogged most likely full of ice with another sheet of ice on top of it.you could unplug for atleast 24 to 48 hrs.or try taking the back panel off in freezer,your panel may be what you set your food on in freezer but if youe see screw that hold a panel in place in the back of the freezer thenremove all screws and if you have ice maker remove it by taking screws out of top and some have one screw in bottom unplug ice maker and remove back panel.you can take a hair dryer and turn the ref. off and heep blow dryer on ice until it starts draining by itself.you may want to see if you have a drain catch in ref.it will be located under settings in back.it will be rectangle shaped like a cup.pull it out and see if garbage build up is in it.you may not have a drain catch.
Mar 10, 2009 | Refrigerators
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
22 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
