Question about HP PhotoSmart 7520 All-in-One InkJet Printer
Hp photosmart 7520 error code B884E6B0
Hp 7520 photosmart all of the lights on the printer's display are flashing with a message saying "Printer Error: There is a problem with the printer. Turn the printer off, then on." When I turn it off, then back on, the HP logo appears with a loading bar under it. Then it makes a quick noise, shows a blue screen with "B884E6B0." Then the lights go back to flashing with the same error message as before. i have turn it off and on buy the power. and re stall it still will not work can you help
5 Suggested Answers
SOURCE: Scanner error
sounds like a bad power supply or hvt, have it checked out, can be dangerous
Posted on Dec 12, 2007
SOURCE: Scanner Error
I am having the same awful problem.... This is frustrating!!
ambertexas
Posted on Jun 19, 2008
SOURCE: 0xc18a0206 error on hp photosmart printer
0xc18a0206
C7183 ALL IN ONE
Posted on Oct 23, 2008
SOURCE: HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Posted on Nov 21, 2008
HP Premium All in one printer c 309a all lights keep flashing.
Have you tried unplugging the printer from the wall for 5 minutes to reset it? If that doesn't work you either have a defective ink cartridge or the printer is defective. Due to the very low prices of new printers replacing it in almost all cases is the cost conscious thing to do.
Jan 16, 2012 | HP Photosmart Premium C309A All-In-One...
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
60.40 Error Message on HP Laserjet 5025 MFP printer
OK I had the hp error code some problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
Earnest: May I have the model number of All-In-One you are using?
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
Earnest: Please ignore the above steps
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
Earnest: Let me know the message displaying on the front panel of the printer
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
Earnest: Let us print a self test page from the printer now
James Cowan: OK deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
2) Make sure that the printer is on and loaded with unused plain, white paper
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
Feb 22, 2009 | HP Office Equipment & Supplies
Printer HP Photosmart 2610 all-in-one
I found this link, which i think may help you out.
http://en.allexperts.com/q/Printers-1512/error-message-HP-printer.htm
Copy&paste it in a browser!
May 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
Hp photosmart 2575v all in one error code on lcd screen . Error oxb804000c.  Prints ok. Error message stays up on lcd screen most of the time. Light flashing near the card reader port ?
did a search on hp website and found over 100 hits
go here to find out what your error means
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Photosmart+2575+All-in-One&pid=441248&productBigSeriesOid=441263&spid=441240&opname=HP+Photosmart+2575+All-in-One&contextual_lname=&pname_desc=HP+Photosmart+2575+All-in-One+Printer%2FScanner%2FCopier&ptype=consumer&stype=pn&spname=HP+Photosmart+2575+All-in-One&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=Error+codes&Submit.x=0&Submit.y=0&Submit=go
Dec 23, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP PhotoSmart 7520 All-in-One InkJet Printer Logo
371 people viewed this question
Seeker5211
Seeker5211
