Question about Medical
I'm interested in an inside elevator for my grandparents
    Problem Solver:
  • 12 Answers
Are you referring to an actual elevator or the stairs lift?
Elevators are much more expensive than the stairs lifts. Of course they have to be wide enough with the right curve.
Please take a look at this site:
http://www.daytonaelevator.com/
Posted on Apr 28, 2013
How can i write/email to Helen Garner well known aust author
Check who publishes her books and article and write a letter to her care of her publisher's address.
Apr 07, 2016 | Cars & Trucks
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jul 15, 2013 | Exercise & Fitness
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
2)Alternative:
Jan 08, 2013 | Tunturi T40 Folding Treadmill
When I walk inside my work building my cell phone doesn't accept calls, make calls, texts & internet isn't working. But when I walk back outside, it starts working again. Please help.
This building is preventing cell phone signals from reaching your phone. Try using your cell next to a window where signal are not obstructed by reinforced concrete walls.
Feb 15, 2012 | Motorola Cell Phones
I plugged it in and it will not start. It was working fine yesterday but now nothing.
Did it possibly blow a fuse in the treadmill? Also, Check your circuit breaker as well, and see if a circuit blew that was dedicated to the outlet.
Read the user manual of your treadmill to find the elevation motor. The treadmill fuses are located inside the elevation motor. If you don't have the manual, contact the manufacturer of the treadmill and ask if it can send you one or if there is one you can download online.
Turn off the treadmill and unplug it. If you have recently used it, let it cool down for one hour before opening.
Place the treadmill on its side and use a screwdriver to unscrew the lid off the elevation motor. Carefully remove the fuses. Some treadmills have easy access to internal parts where you don't need a screwdriver. If this is the case, simply lift the lid off.
Take the faulty fuses to a hardware store to make sure you purchase the correct replacement fuses.
Insert the new fuses into the elevation motor and close the lid. Plug in the treadmill to see if it works.
Sep 06, 2011 | Sears Exercise & Fitness
Hello there. I have an A6 with airbag alarm and also engine alarm. I have been told that the engine error is air pressure!. How difficult is to diagnose this fault and also investigate the air bag problem?...
I don't have a solution, but I am interested if Bajaci is your last name. My great-grandparents' last name was Bajaci and changed to Bajace upon their entry into the U.S.
Thank you for your time.
Christine S. Nunemaker
Jan 15, 2010 | Audi A6 Cars & Trucks
I have a family slo cooker but no manual
Hi Stephen
Silly question, but is it an old tower slo cooker family size?
If so would you be interested in selling it. My flat mate has just smashed the ceramic pot and require a replacement urgently as my grandparents gave it to my parents as a present and promised I'd look after it.
REgards
Julie
Dec 27, 2009 | Kitchen Appliances - Others
Scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Aug 23, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Medical Logo
549 people viewed this question
Top Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Medical Expert? Answer questions, earn points and help others
