Question about Bosch Classixx WFL 2066 Front Load Washer
Drainage 30cm my washer drainage pipe is 30cm high is this a problem?
    President:
  • Bosch Master
  • 662 Answers
If you do not put your exit hose into it, your machine will not work. Do not seal it, there should be air; neither should it fall off during the wash. That height is mandatory for front loaders.
Pl click if helped. This help is free, doing it for fun.
Posted on Apr 28, 2013
Maytag front loading washer will not drain...
there could be a few issues, either the evacuation pump is not working or getting power to pump the water out. or the drainage pipe is blocked.
there is also a filter in the bottom of the machine that could be blocked
check the filter is clear, if you remove it be prepaired for a lot of water coming out. check the drainage hose to ensure it is not folded or blocked.
I hope this was useful.
Feb 15, 2013 | Maytag MAH6700A Neptune High Efficiency...
I have the Flectrolux ewf1087 washing machine and it came up with err 20 and it just stuck now, I have turned off the power and turned it back on again with no change, ant ideas?
Drainage problem. If it is a new installation the possible causes can be:
- The drainage hose is too deep in the drain (can only be max. 10 cm. in the drain, and the drain height may be a minimum of 30cm and a maximum of 80cm from the floor);
The drainage pump may be blocked (clean it);
- The drain is clogged.
Mar 12, 2012 | Electrolux Washing Machines
The cycle washes and agitates but then a Err 20 shows up before the drain cycle. When i restart on the drain\spin cycle the machine starts again but no spinning happens
Mar 12, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error 20 (E20) and starts beeping and stops working? Any ideas what it could be? Thanks kindly
You will LOVE Electrolux for this... Go to:http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
....and click on START ANIMATION for a complete explanation of how you clean the filter on your machine
Jun 23, 2011 | Electrolux Washing Machines
Rinse fault f18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine. Drain pipe clogged. Follow insrtuctions that came with machine to drain using the little pipe bottom right. Then unscrew & clean rotor. pull out wahing machine and check drainage pipe at back is not blocked. Unscrew the drainage pipe from the sink waste and clear out. Also enaure pipe is kept high off floor and is not too long. This will help drainage and prevent pump trying to pump waste water upwards. If the pump is too old or worn out then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | Bosch Exxcel WVT3250 Front Load Washer /...
What does E7 mean, or what area needs repair when E7 code comes up on a Samsung wf306lawxaa ? It won't run, but it will drain and add water. The tub moves when pushed by hand, but I can hear change...
Hi, these error codes are to do with water supply and drain.Check the water supply has not been turned off or is not working for any other reason . Outside work can often disrupt water supplys! Blockages of the pump and filters need to be checked also is the drain pipe at the correct height (at least 18 inches/45cm from floor) and if pushed into a stand pipe , not pushed to far down (12 inches/30cm is usually suffice). If your drain attaches to the sink waste , check the nozzle is clear and drainage is good.
Take care
Jun 25, 2010 | Washing Machines
Washer does not drain water
The major reason for this to happen is the clogging of the drain pipe of the washing machine. If, even after you clean the drainage hose, the problem persists, there may be other problems.
Next possibility could be that the drainage pump which drives the water out of the drainage hose may be clogged! So, remove the drainage pump and clean it. That should solve the problem. it might also be that the belt of the drainage pump motor may have loosened. If this is the case, you have to simply tighten it.
Take care.
May 30, 2010 | Whirlpool LSR5132PQ Top Load Washer
Help
i dont know if this is right but your washer might be old or it might need a flu pipe. the other reason is that one of the other pipes like the drainage pipe is blocked or old or rusty and cant let water past it, since your drainage pipe is different from the washing pipe the water stays their and you need to turn the spin cycle on to let it pass through the washing pipe instead of the drainage pipe.
Dec 27, 2008 | Kenmore 46462 Front Load Washer
How to Clear Drainage Pipe?
High pressure water jets are good, but if you do not have the equipment, a large quantity of very hot water will do as well. This will melt the deposits and flush them down the pipe. I flush my home's kitchen and lavatory drains once a year with a large stewpot full of scalding hot water. This must be done with great care by someone strong enough to keep the pot under control. Wear a long sleeves and pants and a raincoat over to protect from splashes, use heavy mits and pour slowly. Take steps to make sure no children or pets can come near. Make sure your path is completely clear. Failure to take great care can result in a very bad burn. Done regularly, this maintenance can greatly reduce, or even eliminate, blocked waste pipes.
Aug 27, 2008 | Danze D495008PBV Polished Brass 1-1 / 2...
Bosch Classixx WFL 2066 Front Load Washer Logo
80 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
