Question about Bosch Washing Machines
Fix push button cap bosch washer model wfe2021
Model wfe2021
I have a dishwasher bosch model SHE3AR55UC/07. I press the ON button to turn dishwasher on. And when I press START button, the dishwasher does not start.
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Aug 27, 2016 | Bosch Dishwashers
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
My Kenmore H2 Plus needs to be reset to factory settings. Cannot find how to in the manual.
Not sure if this will work with this model but try this:
1-Turn off and unplug the machine. Plug the washer back in and wait for the control panel to light up. This resets the washer back to the original factory settings.
2-Unlock the control panel by simultaneously pushing and holding down the Options and Select button for 10 seconds if you see a lock icon on the control display.
3-Push whichever new options you need, and wait for the control panel to flash and reset the washer's options.
Apr 22, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hi, we have a Bosch washer model WFK 2401, in which we just replaced the door latch assembly and drain pump, and now it seems the electrical panel is going out. Since yesterday, when we push the...
Check with the repair man but I bet he didnt plug the panel back in all the way when he repaired it,maybe wanting another call. check it out
Feb 15, 2011 | Bosch WFK 2401
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
It lights up but will not start, lint light is on.
take a pen with the cap on and push the start button really hard. It's a temporary fix but it should work.
Oct 15, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
Error E04 on bosch nexxt wfmc32000c
Bosch E04 Solution:
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say! I'd guess you could get wet.
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free.
  5. Once the door out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hands. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  6. Pull out the trap that you just unscrewed and you'll most likely see the item that caused the E04 error code. I found one of my two year old's socks. There is an side of the trap that is marked that it needs to be installed facing downward, so watch for that when you put it back in.
  7. Read these directiosn upside down and backwards to put it all back together.
  8. Run a load and watch for leaks. You could leave the door off until you are sure you screwed the cap in tight enough.
Jul 12, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
