Question about Tektronix TDS 500B/600B/700A Oscilloscopes User Manual 070-9719-00
Oce tds 600 error code
Error code 23501
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
Sep 01, 2013 | Office Equipment & Supplies
Oce tds 800 error code 06701
This is a sensor problem. What i did on my TDS 800 was open the top door(A) and bent up just a tad bit the sensor that is on top that clicks when you close the door. What was happening was that after i cleared the jam the code was still saying to clear the jam, which there was none. After bending it up and closing the doors it started working right away.
May 30, 2012 | Office Equipment & Supplies
Oce TDS 600 scanner error code 10501
the heater stays cold during run,heater bad or false contac or ssr defect
error 10501
May 22, 2012 | Office Equipment & Supplies
OCE TDS 600 error code 22017. Do you Know what it is >?
There is a problem in the power supply section. Call for service, this is not user fixable.
Oct 04, 2010 | OCE Office Equipment & Supplies
Oce tds 600 Error code 15504 machine stopped in the middle of a run (like every 5 sheets) could be an overheat problem
There seems to be a feed problem. I googled the error 15504 for the Oce printer and got this page. We did this (see photo) and that seemed to sort the problem out for the meantime (until service guy gets here). I dare say it's a sensor somewhere. So jam a roll of cardboard from a used roll in behind the roller (as in the photo) and that does the trick. Hopefully this works for anyone else with the problem.
Sep 02, 2009 | OCE Office Equipment & Supplies
Tektronix TDS 500B/600B/700A Oscilloscopes User Manual 070-9719-00 Logo
70 people viewed this question
Top Tektronix Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Tektronix Science and Laboratory Expert? Answer questions, earn points and help others
