Question about Olympus SP-350 Digital Camera
Zoom error message
When I try to take a picture with my auto setting, the camera opens and I hear a straining noise. It happens a couple of times, then shuts down and the error message comes on the screen.
  • 1 more comment
  • Manimaran Nov 12, 2007
    I have SP 320 camera - whenever i try to power it on it makes a strange sound and displays zoom error and shuts down.The zoom is is not moving anywhere
  • Anonymous Nov 22, 2007
    I have the same problem with my sp-550uz. The solution described doesn't work.
  • Niks pics Jan 03, 2008
    same
QUOTE "Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse" I tried this even though I did not know how you can twist the telescopic zoom lense while it is in the camera all of the way. So I pushed and proded around the lense while continuosly pressing the power button and poof, the lens opened and zoomed. Life is good.
Posted on Aug 11, 2007
  • 641 Answers
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Aug 10, 2007
All of my shots are grainy--really grainy. My old 8 mpx camera took beautiful, tack-sharp photos. This is 14 mpx and it looks terrible. Someone suggested that maybe the contrast needed to be adjusted ...?...
Unfortunately with higher mpxs sometimes you pay for it with higher noise levels. The smaller pixels are more sensitive and can cause noise. A couple of things you can do to help control the noise is make sure your pictures not underexposed, you may need to bump up you exposure compensation a little as long as you don't end up too bright.
You can also try to shoot with the lowest ISO setting your camera has. High ISO = NOISE!
Last you can run your photos through a noise reducing program such as"Noisware" their community edition is free. http://www.noiseware.com/download_nwsa.aspx
PS Contrast settings will do nothing for noise.
May 03, 2011 | Kodak EasyShare Z981 Digital Camera
E:61:00 error
E 61 00 Difficult to adjust focus Inspect the lens block focus reset sensor
E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
E 62 00 Steadyshot function does not work well. Inspect pitch angular velocity sensor
E 62 01 Steadyshot function does not work well. Inspect yaw angular velocity sensor
The simple solution to fix that error message was to the let the lens fully extend and give the lens a good whack. Possibly this error message for this means, that the auto focus motor was past the maximum set point.
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
· Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
Here is the first alternate method (AVI format)
Here is the second alternate method (AVI format)
Good luck.
May 03, 2011 | Cameras
The zoom browser does not recognise the camera is connected to PC
Windows updates change the registry. Sometimes this means our connected equipment no longer works. Now it is time for you to start using a separate card reader.
May 17, 2010 | Canon IXUS 80 IS Digital Camera
Weird noises when it's on and zoom button noise picked up on vid
change auto focus to single focus mode,
since it is on continuous auto focus on default, it would focus all the time so you don't need to click half way before taking a picture
Mar 22, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
I'm receiving an lens error message i hear noise but zoom won't function. Can't take pics! help please have taken battery out has happened before appreciate any help!
if the lens is detachable take it off and clean the contacts there could just be some dirt on them if not make sure the switch on the lense is set to A not M
hope this helps
Mar 22, 2009 | Nikon Coolpix 5700 Digital Camera
Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Sep 08, 2008 | Nikon D40x Digital Camera
Samsung Digimax 530 - Zoom Error
I had to send the camera to NJ for repairs. It cost $58 for parts, labor, and shipping.
Apr 29, 2008 | Samsung Digimax 530 Digital Camera
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Mar 06, 2008 | Fuji FinePix Z1 Digital Camera
Olympus SP-350 Digital Camera Logo
375 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
