Question about D-Link DIR-505 Wireless All-in-one Mobile Companion Travel Router
Connection My wireless dir-505 didn't make connection with my wireless speedtouch modem. He is always being to find an ip-adress. What is the problem?
mlake33
  • 427 Answers
SOURCE: Router seems to drop connection frequently
What a static ip is, is the ip address that the router automatically assigns to other equipment. (computers, xbox, ect.) Find D-links customer support line for help.
Posted on Apr 12, 2008
SOURCE: dlink DIR-615 wireless connection problem
hi. with regards to your concern. there is a possibility that the wireless network adapter driver is corrupted.. try uninstalling the driver for your wireless adapter and reinstall again. once setup is done, view the available wireless connection and connect.. it will ask u the password if there is..then it will connect. if this solution dont work.. try to check your wireless settings, maybe there is a problem on the settings..
Posted on Aug 08, 2009
  • 6 Answers
SOURCE: Modem + router = no internet????
Ok, on the back of the router, the port that you have the network cable plugged in does it say "Wan" or "Uplink" or is it just numbered?
If it is numbered, you need to plug move the cable to the port that says "Wan" or "Uplink", this is typically one of the last ports on the back side of the router and sometimes it is actually sort of set further away from the other ports (nominally). The Wan or Uplink port is the one you would want to plug the cable you are going to use to connect the router to the modem. When you have it correctly installed, you will see a couple of lights on the front of the router that are lit up. These lights will correspond to the port you have the cables plugged into on the backside of the router. One port should say "Internet" or "Wan" or "Network" the other port (the one the cable going to your computer is plugged into) should have a number near/over/in front of the light, and the light should be lit.
Once you have the cables correctly connected, you should power cycle all 3 devices in the following order:
Shut off your computer
unplug your router
unplug your modem- now wait for a good thirty seconds just to be safe, and you can start powering things up in this order:
Plug in your router, and wait until it has finished flashing and powering up,
Then plug in your router, and wait until the light for the "Wan" or "Uplink" or "Internet" port has stopped flashing.
Now turn on your computer and log in to it. If you have followed these steps correctly it will resolve 90% of  all router/modem setup problems. If this does not resolve your problem, you may have to configure the router's internal configuration with your internet provider's name and maybe even a user name and password- these instructions would be available from your Internet provider, and they should be able to provide you that information if you need it and have forgotten it/misplaced it.
I hope this helps.
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
Posted on Sep 16, 2009
ihwsolutions
  • 137 Answers
SOURCE: D-Link DIR 655 - DHCP server but no internet
This usually happens when the router has timed out trying to grab an IP address from your modem.
I suggest unplugging your router and modem, waiting 1 minute, plugging in your modem, wait 1 minute, plug in your router, wait 1 minute, then try to connect again.
If this solution has helped you, please take the time to rate me.
Posted on Oct 04, 2009
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
I cant open my WIRELESS ROUTER |WL-520G - RT (WL520GC) on my browser; if i open the default gateway the isp modem settings pops out not my asus router seting... pls hep
Hi!
I tried to figure out some explanation, and I think it's possible that both WAN side of the router and LAN side of it have same types od ip adresses, maybe the default 192.168.1.***. That means that the WAN port of the Router, the ethernet port of the modem, the wireless and LAN ports of the router have same tuype of adresses, maybe all asigned by DHCP.
To be sure, I suggest you to:
1. turn of the modem
2. check that the network connection obtains ip adress automatically
3. in a dos prompt (START - RUN -CMD) type IPCONFIG, it will return among other infos the adress of the default gateway.
4. now type that adress in the browser.
5. if it works, log on to the router and change the LAN settings so that the adresses used in the LAN will be different from the WAN, let's say 10.10.10.1 and so on
Aug 06, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
Oct 04, 2009 | D-Link DIR-655 Wireless Router
I have 1 modem and 3 wireless router and 2 switches, the modem connect to the first router then the router connect to the switch. the two router connect to the switch and also the other switch connect to...
If you have same router their IP must be conflicting with each other and may be with modem also.
Make sure you do not have any conflicting IP in your network to avoid network collision and it will not create any problem
your both router might have IP as 192.168.1.1 and may be your modem also.
Sep 30, 2009 | D-Link DIR-300 Wireless Router
When I connect my wireless router to my computer the speedtouch cannot be detected by my computer therefore I have no internet on my computer but I have wireless on both laptops which are directed through...
you probably have the router set to static ip so first you have to assign your pc with an ip range of the router , then log in the router set to dynamic ip and make sure you connect cables as per router manual. if it does not work then disable firewall , enable upnp devices . After configuration of wireless router you can enable firewall again. If you are using vpn with speedtouch then you should configure speedtouch to store username and password to connect to isp
Sep 11, 2009 | Computers & Internet
Ps3 to internet
Difficult to explain but i'll try:
You got 2 options.
1. Buy a router and connect the modem to the router wan port and find a manual how to set it up. Then through your router you can connect (a lot of) pc's, laptops or ps3.
2. Buy an extra network card and a crosslink network cable cat5e. Use software like gatekeeper to connect both to internet.
maybe the second option is the best because sometimes isp providers register you mac adress(unique adress of your network device). It's not the fastest solution.
The first is the most professional but require some knowledge of routers, ppoa, pptp, fixed ip, Wan ip, and lan ip.
I did the second option a lot with speedtouch modems and draytek routers.
Good luck, let me know if you need more assistence.
Dec 29, 2007 | Computers & Internet
Wireless router does not connect to the internet
try to check if the ip of modem is the same as of router , if so change router , example : if both work on 192.168.1.1 than change router to 192,168.3.1 this might solve the problem , it did for me .
Nov 02, 2007 | Belkin Pre-N (F5D8230-4) (DBF5D82304)...
D-Link DIR-505 Wireless All-in-one Mobile Companion Travel Router Logo
22 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
