Question about Sony Cyber-shot DSC-H2 Digital Camera
Anything dmc The usb port is broken and I have pictures on the internal memory is there any way that I can save them to memory card?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Yes. Use the Copy command in the Memory Stick Tool menu as shown on page 64 of the DSC-H2 User's Guide:
http://www.docs.sony.com/release/DSCH2.pdf
Posted on Apr 28, 2013
tazdev
  • 75 Answers
SOURCE: Transferring pics
I think there is a copy to card option in your camera.
It would enable you to transfer pictures from internal memory to your SD card.
You may check the website of your Camera Manufacturer and download the English manual online.
Posted on Nov 30, 2007
welcomejee
  • 10594 Answers
SOURCE: Pictures only save to internal memory, not memory stick...
DSC-W80 sybershot camera has facility when you insert Memory Stick in its slot, it automaticaly selects this memory card and starts saving data on it and internal memory got suspended.
Pls check memory stick 2GB and inert it correctly in memory slot in camera.
Posted on Aug 14, 2008
naveengupta8
  • 18 Answers
SOURCE: camera says "internal memory full"
Goto srtting > storage > set primary storage as memory card.
Posted on Jul 08, 2009
  • 102366 Answers
SOURCE: transferring pictures
Go into the Setup menu and select Copy. This will copy all images in internal memory to the memory stick.
Posted on Jan 28, 2010
  • 11967 Answers
SOURCE: I have the SAME exact problem as lostark98 from
In the camera's menu, find an entry for "copy". It should give you the option to copy the pics from the internal memory to a memory card.
Posted on Mar 12, 2010
Dmc ls80 transfer
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Jul 22, 2014 | Panasonic Lumix DMC-LS80 Digital Camera
I have a Panasonic Lumix DMC FX10. I need the free software thats loaded on the desktop in order to download the pictures through the USB cable please. This is presumably the software that came with the...
Another way to download your photos. Remove the memory card from the camera and insert the memory card into an USB memory card reader. Connect the card reader into the USB port on your computer. The computer will see the memory card as an external storage device, you can open the folders and files and copy them to your computer.
Nov 18, 2011 | Panasonic Lumix DMC-FX10 Digital Camera
How do i get internal pictures off my panasonic Lumix DMC-LZ3
If you take the memory card out of the camera, you can view the internal pictures one by one, and delete them, or transfer them to you computer through the cable...they will show up as another drive in Computer, or My Computer, depending on which version of Windows you are running.
Good luck, and hope this helps.
May 03, 2011 | Cameras
How do I copy pictures from a USB port to the memory in the Digital Picture frame?
it depends on your digital frame becuase some frame cannot be save the picture on the internal memory. if the manual says that you can save or upload try to go setting and look for copy then choose from( memory card to internal or internal to memory card)
goodluck my friend
Jul 13, 2010 | Smart Parts Digital Picture Frame
DMC-FX55 memory problem
Press menu/set...playback menu....select "copy" Make the choice to copy the internal memory to the card and select "yes".
Jun 30, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
My computers are not recognizing the camera is hooked up with the cable, and thus I can't get the pictures off the camera. I can use a card reader for the ones saved to the memory card, but how do I get...
i don't know how to save the pictures onto the memory card maybe in your settings you can change it to external memory or something and your USB cable is probibly stuffed up so you'll have to get a new USB cable goodluck ;) and please rate this solution...
Jun 06, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
How do I switch between internal memory and memory card?
When you remove the card, can you review the pictures that are on the internal memory? If you can and you want to save them, download them to your computer. Then, with the memory card still out of the camera, format the internal memory.
Oct 27, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Important photos are stuck in the internal memory of my camera.
Select the Display mode with the top dial. Press the Set button to bring up the menus. Press the Rev key to scroll down through the menus. On the second page of menus, select the Copy menu. Then press the Lightning Bolt key to scroll right. Select the top of the 2 menu items. This will copy the internal pics to the memory card, assuming you have a memory card inserted.
May 27, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Help! My pictures are trapped on my digital camera!!
On PLAY mode, with a valid memory card inside, press MENU/SET, goto to COPY, select internal--> memory card, select YES, and then MENU/SET.
You better charge your battery before doing copy. Don't turn off the camera during copying.
Good luck.
May 23, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
DMC-FZ28 camera memory
First of all, it's faster to use a fast SD to USB adapter with a fast SD card. This beats attaching a (slow) cable to the camera by far. Plus, the method of transfer gets confusing when considring internel memory via cable, on some systems. Skip the cable. I like to get my SD card with matching USB adapter. Both of these need to rated fast. Not just a "Class 6" and not just big but FAST. It saves your time! Repeatedly.
Therefore, switch to "Play" mode. Go down to the "Playback" menu and find "Copy". Copy "in" to the SD icon. That's it.
You might want to clear you internal memory too. But only after your pictures are safe.
Dec 04, 2008 | Panasonic Lumix DMC-FZ28 Digital Camera
Sony Cyber-shot  DSC-H2 Digital Camera Logo
27 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
