Question about Motorola Mobility MBP36 Digital Video Baby Monitor - 2.4GHz Wireless Technology
No sound just video - Motorola Mobility MBP36 Digital Video Baby Monitor - 2.4GHz Wireless Technology
  • 4 Answers
Okay, a couple of things.
This speaker issue seems to be a common problem, and I believe it most likely occurs due to rough handling of the unit. Although it seems to be fairly rugged, it should be treated gently. In general, I would only handle it as much as needed, and be careful when setting it down, and make sure it doesn\'t get dropped.
With that being said, the unit can be opened, however doing so will break at least some of the "snaps" that hold it together. If it is out of warranty and you need to get into it, this is a necessary evil.
Step one: Remove the battery cover (one phillips screw) and battery. There is a second, smaller phillips screw that also must be removed.
Step Two: At this point, you are ready to separate the unit. Using multiple flat head screwdrivers, pry the unit open (starting on the right side when looking at the unit from the front) then "wedge" the pried open area with a second flathead screwdriver as it will naturally want to close back up. Continue working your way around the unit, being careful not to crack the screen. You will break some tabs along the way, but I see no way around this as they are not visible to try and release them any other way.
Step Three: Once you have separated the two halves of the unit, the power button will have fallen out. This is okay as it will slot back into place when you reassemble the unit. Just set it aside and do not lose it.
Step Four: I do not know the exact failure mode of the speaker, however you will find that it is apparently strongly secured in the housing with an adhesive (epoxy or some sort of resin) and if you had to remove it it would be difficult and not very fun.
MY SOLUTION: I hooked the battery back up and turned on the music feature, which should play music from both the camera and the parent unit. In my case, I found that tapping hard on the speaker (it took more force than you would think) would cause the music to momentarily play. I found that wedging a screwdriver between the plastic housing and the speaker body would make the speaker play. I used a small nail (like a trim nail for small trim) and wedged it between the speaker and the housing, then trimmed off the excess of the nail.
This solution is not ideal, but it was relatively quick and worked to keep the unit functioning for now. I imagine that there is some sort of connection that has failed internally in the speaker, and that wedging it has (at least temporarily) reformed the connection. I imagine that a new speaker could be installed with some work to remove the old speaker, and then a new one soldered in and glued into place.
Once I got the speaker working, I disconnected the battery and carefully replaced the power button, then the two halves simply snapped back together. I replaced the screws and reinstalled the battery, and all has been working as it should. The case does show some damage from my prying, and it doesn\'t fit as tightly as it used to with the broken snaps, but it does hold together and doesn\'t have any issues in normal use.
In all, it certainly beat buying a whole new unit, especially since it was working just fine other than the sound. Good luck!
Posted on Feb 21, 2014
I have no sound with movies
About 47,000,000 results (0.61 seconds) Search Results
    Even if a movie is played back, no sound is heard.
    faq.fujifilm.com > Support > Q&A > Digital Cameras
    Aug 13, 2012 - If no sound is heard while playing back a high-definition movie "HD" or a ... and Z series digital cameras · Should I remove the battery from the digital camera after use? ... If you need answers, please use the contact us form.
    Ask Olympus: When I shoot videos I'm not getting any sound ...
    www.olympusamerica.com > Learn Center
    Olympus CorporationThe camera may also have options to shoot videos with and without sound and at ...When shooting videos with sound, the DIGITAL ZOOM must be set to ON so ...
    Video has no sound!: Nikon Coolpix Talk Forum: Digital Photography ...
    www.dpreview.com/forums/thread/3498156
    DP ReviewJun 4, 2013 - What happened ... and can I get the sound somehow ? .... If no, you mayhave a defective camera with a dead mic or something. If yes, try ... Playing QuickTime videos on an Android tablet: Android Talk ...
    Mar 2, 2013
    Help!-G12 video sound: Canon PowerShot Talk Forum: Digital ...
    Aug 22, 2011
    Fuji 6900: No Sound Recording: Fujifilm FinePix Talk Forum ...
    Apr 6, 2001
    More results from www.dpreview.com
    Amazon.com: Questions And Answers: Lack of sound in video playback ...
    www.amazon.com/Lack-sound-video.../1?_...
    Amazon.com, Inc.
Jan 21, 2016 | Cameras
Can not use my sound bar to play music videos
S video cor is only for video, not sound. Your model is also the Hitachi CP-X200
What is the source of the music videos?
Mar 08, 2014 | Dukane ImagePro 8755G LCD Projector
Wiring color code for lcd screen
AV VIDEO CABLEYellow- Video Red- Right sound R White- Left Sound L
Component Cables RED ORANGE- video BLUE- video GREEN-video RED- audio R WHITE-audio L
HDMI provides both video and audio all in one.
Optical out Audio Audio format to surround sound. Better sound quakl
Hope this helps
Jul 20, 2011 | Televison & Video
My computer is on mute, and the youtube videos dont have sound.every time i put sound on the video, it says mute, and every time i lower the volume all the way, it unmutes.
The YouTube video controls the output sound-level that it provides to your computer.
But, if you "mute" your computer, the sound-level is ignored.
When you "unmute" your computer, then the sound-level control on the video will control the volume of the current video.
Jun 06, 2011 | Computers & Internet
Trying to transfer video to my computer (iMovie application) through the s-video port. Picture is perfect but sound does not transfer.
S-Video does not have sound, you will need to run separate audio cables to your sound cards input ports. S-Video is only for the video signal (Chroma and Luminance), there is no provision for sound.
Feb 13, 2011 | Hitachi DZ-MV230A DVD Camcorder
No video, occasional sound.
get new av jacks that might be the problem
Aug 20, 2009 | Sony Playstation 3 (PS3) Console
Blue screen, no video, but has sound
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
Dec 08, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
PSP Video Sound Problem
hi. i no why. it is your speakers it has some thing in it or maybe they have just broke. well that is all i can say so bye
Sep 17, 2008 | Sony PlayStation Portable (PSP) Console
S-video and sony camcorder, no sound with playback.
Did you connect the sound cable as well? S-Video only supports video, you will have to connect a seperate sound cable for the sound.
Mar 23, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
No sound when capturing video from Handycam to computer
There is no sound carrier on an S video connection. It's Video only. use the AV left and right cables for the sound. It is normal not to monitor audio when capturing.
Dec 02, 2007 | Canon ZR60 Mini DV Digital Camcorder
Motorola Mobility MBP36 Digital Video Baby Monitor - 2.4GHz Wireless Technology Logo
197 people viewed this question
Top Motorola Mobility Baby Gear Experts
Dorel UK
Dorel UK
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
