Question about Krups Nespresso Xn250140 U Coffee Machine, Pure Cream
KRUPS XN250 THREE LIGHTS FLASHING
Nespresso U - the lights keep flashing but doesn't work
have you done descaling try pressing the two buttons at the same time but keep holding them for 5 second tell me is it flashing fast or slow?
Sep 08, 2014 | Krups Nespresso U Xn250a40 Coffee Machine
All lights are flashing
It is in need of repair or service.
Mar 23, 2014 | Krups Coffee Makers & Espresso Machines
All three lights are flashing. what is the problem?
seems like water got into the electronics. try unplugging and moving it. there maybe water under it either way leave it to dry for a day or 2 then try it.
Aug 15, 2013 | Krups Nespresso Xn250140 U Coffee Machine,...
Krups nespresso u 3 flashing lights
The Machine has entered Descaling Mode. To exit, wait until all greens are flashing then hold all three buttons down at same time for about 3 seconds until machine bleeps. It should then perform as normal.
Jan 25, 2013 | Coffee Makers & Espresso Machines
Krups 889 red & green lights alternate flashing and machine will not do anything else. how can I get it out of this mode?
I have the same machine and the spent coffee tray wasn't going in and after cycling with pressing three times then clicking three times all the lights would cycle between red and green and the machine would do nothing. It turned out to be a jammed eject motion of spent coffee. the coffee was pressed in but wouldn't eject into the coffee tray so the flap wouldn't go all the way up making the tray not go in. I took the back of the machine off and used a screw driver to "help the unit up during the cycle". When the machine would screw down and PRESS I'd not do anything but as soon as it would screw up I would lever my screw driver and HELP it up....after two or three attempts it screwed all the way up and ejected the coffee and now it seems fine.
Jan 09, 2013 | Krups Orchestro 889 Espresso Machine
When making coffee it goes for a bit but then stops and the buttons start flashing what is this fault and how to fix it?
Hi. the flashing lights usually means that there is a water stavation fault. Not getting enough water, so there must be a blockage or pump fault. Dazza REPAIRER
Sep 23, 2011 | Krups XP 4050 Espresso Machine
Not sure how to take it off cleaning mode. The cleaning button continues to flash?
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={EBDB947E-33FB-42E0-B662-0E13E8D1D4FB}&SelectedProdRef=XP9000
here is a link to the manual. u will need adobe to open it
Jan 20, 2009 | Krups Super Automatic XP 9000 Espresso...
Krups Nespresso Xn250140 U Coffee Machine, Pure Cream Logo
420 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
