Dual CS714Q the speed of mij turnttalble is 244 turns /pm and not adjustable form 33 and 45 turn/m have anyone the diagram, with the specs of the circuit boards In the standard service manual, are no circuitboards or diagram visible
SOURCE: LG MZ-42PZ14 service manual
Had another plasma the same in for repair so managed to see value on other board!
Managed to find the service manual in workshop but no schem of y susatan.
TV now fixed
Posted on Sep 08, 2008
SOURCE: TV Circuit board diagram
My SONY TV Model : KV-XJ29M50. LED will blink/flash twice right after power turn on and cannot display picture.
Posted on Jan 14, 2009
  • 24 Answers
SOURCE: Service Manuals for PVR160 by Evesham
I'm not sure if this will help, but here is a possible contact to try and get a manual. I know that Evesham.com went out of business. but I found this information on
http://en.wikipedia.org/wiki/Evesham_Technology
A group of former staff from Evesham headed by former Evesham employee Robin Daunter started Tewktech, a company selling computers and offering repairs for a variety of brands including Evesham Technology.
http://www.tewktech.com/
good luck.
Posted on Aug 04, 2009
jvpacoin
  • 91 Answers
SOURCE: i need a circuit diagram and service...
HJ i have you want it? ask Jason to call me lol, anyways bro you dont need the manual for this units what you have to do is to check stage by stage. regards to everyone there.... uh uh anyways joey is there let him do it. hes good to that :)
Posted on Aug 14, 2009
  • 226 Answers
SOURCE: marantz pm 550 dc, service manuals and schematic
Hi,Give this a try. I think it is what you are looking for.
http://www.eserviceinfo.com/download.php?fileid=48367
Click where it says "Download >> To download the file, please, click here
It's a multipart file, so you need to download Multipart 0,1
open it using winrar and the open it to view the pdf file.
Note: you must have a pdf viewer to read the file.
If you need anymore help with the amplifier, then please ask.
Regards - Anthony
Posted on Feb 28, 2010
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
Clutch adjustment specs
The best specs to use and the best place to find these specs for adjusting your clutch is to purchase the service manual for your specific motorcycle. It will give you step by step instructions as well as diagrams and pictures to make it even easier for anyone to DIY! Good luck!
Sep 15, 2013 | Yamaha Motorcycles
1982 YAMAHA XT250 CARB QUESTIONS TIPS OR DIAGRAM NEEDED
ITS LIKE ADJUSTING THE IDLE SPEED SCREW LOOSEN OR TIGHTIN LISTEN TO ENGINE TUNE BY EAR.
Jun 23, 2013 | Motorcycles
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
Pro form consel displays PO and will not start
Dear Sir:
This is probably a 1)faulty speed sensor or 2)speed sensor is not plugged in properly. 3)faulty motor control board 4) adjust the reed swithc. The error codes will differ between makes and models but could be e1.
see the diagram for boths adjustment. sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Feb 18, 2012 | Exercise & Fitness
How do i fix an e2 error and get a wiring diagram
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
E.CUADR
MANAGUA, NICARAGUA
Oct 21, 2011 | Proform 730 Folding Treadmill Model...
E2 error on pro form 730 key in belt and motor run about 5 sec and shuts down sensor light blinks but not a steady light
Dear Sir:
I will try to help you, use the patience and carefully: need screwdriver, hex, allen+Dvom(DigitalVoltemeter)
Optic Sensor
Motor
motor brushes.
Other
board, marked U5. .
continuity.
Troubleshooting: ERR 2 - No Motor Movement
Turn unit power off and then on to clear the ERR2 message from the display. To test whether the drive
board is putting out power to the motor, insert multimeter probes on the M+ M- connectors and press
the speed up key. . (Note: To avoid ERR2.)
Power to Motor
If the drive board puts out power to the motor, but the motor does not operate, either the motor wires or
motor is malfunctioning. Test wires for continuity. Inspect connections. Perform an ohm test on the
motor . Inspect motor brushes.
No Power to Motor
If there is no power to the motor, either the signal is not arriving at the drive board, the transformer
or inductor is bad, or the drive board is bad. Inspect the following:
??? Display - Does the display beep when you press speed up? If so, the display has sent its signal.
If not, inspect overlay-to-display connections. And press down on the main program IC, marked U5.
??? Wires and their connections - inspect data cable connections from the display to the drive board,
test data cable continuity, inspect M+ M- wires from the drive board to the motor.
??? Inductor (6310 only) - inspect inductor and its wires and their connections. .
??? Transformer - inspect the transformer and its wires and their connections.
??? Drive Board - inspect the drive board for burnt or cracked components. Inspect LEDs (See DRIVE.03
and DRIVE.04). Press on the drive board IC chips to ensure good connection. If the power indicator on
the drive board, LED8, lights, but there is no power to the motor, and other components are good,
replace the drive board.
wITH THIS YOU FIX IT. If you need further assistance, please reach me
SINCERELY. GOD BLESS YOU.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 20, 2011 | Exercise & Fitness
I WANT TO INSTALL TALLY 9 AND USE IT WITH OUT INTERNET CONNECTION WILL IT BE POSSIBLE. HELP
To activate your license offline follow the steps shown: Go to Gateway of Tally ???? Press F12: Configure > Licensing > Offline > Activate The Activation Form appears ???? Enter the Serial Number in Serial field ???? Enter the Activation Key in Key field ???? Enter the Email ID in E-Mail field ???? Tally displays a message indicating that the tally_req.lic file has been successfully generated. ???? Copy tally_req.lic file available in the Tally folder to a floppy/CD ???? Paste tally_req.lic file to another computer with Internet connectivity and Tally installed. ???? Start Tally ???? Press F12: Configure > Licensing > Offline ???? Select Send External Request to send the request file to Tally Licensing Servers. The response file called tally_resp.lic is generated and saved in in the Tally folder. ???? Copy the tally_resp.lic file to a floppy or CD and paste the file into the Tally folder where the license has to be activated. ???? Start Tally ???? The Register Now screen appears, ???? Press Enter to work on Tallly
important:if this information was helpfull to you please vote for me and write a comment for me.
Sep 02, 2010 | Computers & Internet
96 FORD F-350 7.3 TURBO DIESEL 5 SPEED
no, it shouldnt have any looseness to it and dual mass flywheels are VERY expensive to replace, BUT yes it can be converted to a solid flywheel, check out autozone.com part number MU1989 or advanceautoparts.com part number 798, that should get you on the right path to curing your problems, i welded the two independantly turning discs of my dual mass flywheel together but i wouldnt recommend anyone doing that without the proper equipment to do so (i.e. precision lathes, cast iron welding rods, etc)
Mar 29, 2009 | 1996 Ford F350 Crew Cab
 Grubhead
Grubhead
