Question about Casio Exilim EX-Z57 Digital Camera
Battery problem or camera problem?
My camera was fine, it was running low on battery, but not completly dead. i took the battery out and put it in the charger. as i was walking away, i noticed the light on the charger was flashing red every few seconds instead of staying on like usual [till its done charging] i thought it was weird but ignored it. later, i put it in the camera and it showed it hadnt charged at all. so i unplugged the charger and left it alone for awhile and tried chargeing it again later. it worked fine and i forgot about it. the next time i went to charge it, again, the camera wasnt completly dead, the charger was blinking. after a while i put the battery back into my camera to see if it had charged at all. for the last week the camera wont come on whatsoever. it acts as if there is no battery in it. ive done everything i could think of to try to fix it and it wont work. im soooooo frustrated, i just want my camera back! =[ im 15, and my parents no squat about technology so im stuck in this one alone. PLEASEEEE help me!
  • 6 more comments
  • jaime frey Aug 11, 2007
    i called the company. and they told me it was a common problem. turns out the lithium battery was bad, i mailed it in and there sending me a new one.
    thnxxxxxx =]]
  • C-rod Nov 29, 2007
    I have the same problem with my Exilim camera. My battery charger just keeps blinking. What did the company require from you so you could receive a new battery?
  • Anonymous Dec 18, 2007
    I have a brand new xmas present..the camera won't charge...red light blinks but that's all it will do.....
  • Mandi28257 Dec 23, 2007
    i had the same problem but i'm not sure if i need a new charger or a new battery?
  • Anonymous Jun 25, 2008
    Have the same problem with it after year of good work
  • Anonymous Sep 08, 2008
    my battery wont change either.. it just blinks
  • Anonymous Sep 10, 2008
    I have the same problem.
  • Anonymous Mar 30, 2014
    worked fine 2 days ago
  • 63 Answers
A new battery should help you to solve this problem.
Posted on Aug 07, 2007
SOURCE:
I had the car in storage for 35 days. Upon startup, battery was dead. I took the dead battery out(only 1 year old) and put in a good battery which started the car, while the car was running good I took out...
You recycle the old dead battery
Have no idea why you even put that back in
Common sense & your friend is correct
You don't disconnect anything on today's
vehicles, even with the key on
Put in a new battery,start the car, warm it up
& drive it for awhile & maybe you will get lucky
& it will complete some of the drive cycles & run some
monitors ,you know nothing about & it will be fine
If not, your mechanic friend should be about to stop
by with the bosses scan tool & help you out
Sep 23, 2011 | 1999 Acura TL
Tip
Fuji a350. When I got the camera, it took many many photos(50-100) with alkaline...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Feb 04, 2009 | Samsung Digimax D53 Digital Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
Nikon Coolpix 5700 was working fine, now it won't turn on. Batteries are fine, but camera just won't power up at all. No error message, nothing but a dead (black) screen. No idea why it won't come on--it's...
Two quick suggestions first is the battery chamber contacts clean make sure they are clean. Are you using a battery pack with rechargeable AA's ? if so check the battery orientation it only takes one out of place. If you are using the rechargeable battery I know you said the batteries were fine but make sure the power is up on the rechargeable. I've had it where I put a battery on charge knowing it was pretty well dead came back 5 minutes later and the light was green, took the battery of the charger unplugged the charger plugged the charger back in and put the battery back on the charge. It then completed its true cycle.
Jan 04, 2011 | Nikon Coolpix 5700 Digital Camera
Stopped taking pictures
How old is the film in camera & when did you put in the film?
Polaroid's battery is built in with the film package.
If the package is old or been in the camera for a long time battery may be low or dead.
Try changing film out.
Good Luck! Hope this helped. Please rate.
MSG back if you need more help.
Mar 11, 2009 | Polaroid OneStep Express Instant Camera
Camera says new batteries are dead
I found out how to fix it. (STEP 1.) Take out all of the batteries. (STEP 2.) Hold down the power button for 30 seconds. (STEP 3.) Put the batteries back in and you should be all set.
Dec 28, 2008 | Canon PowerShot A570 IS Digital Camera
NIKON D80 Can't turn it back on
oops. This is what I'm facing right now! Looking for a solution.
Sep 21, 2008 | Nikon D80 Digital Camera with 18-135mm...
Battery Low with NiMH (won't turn on) OK with Alkaline
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
May 29, 2007 | Samsung Digimax A7 Digital Camera
Battery?
i just got mine today, and the batteries were dead withtin a couple of hours, so yes. mines has decided to go black, it was fun while it lasted,, theres £90 ill never see again
Aug 24, 2006 | Samsung Digimax S500 Digital Camera
Casio Exilim EX-Z57 Digital Camera Logo
254 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
