AMF 82-70 Pinsetter problem
Hi,I have a problem with our pinsetter 82-70 and I really need help to fix it. In its normal operation when the pinsetter turns on, press the cycle switch then the operations should start with 1st cycle, instead of this the pinsetter keeps cycling as a 2nd cycle with the table only work to put down new set of pins without the sweep. I tried to disconnect all mechanical parts that link to the table but it keep going. During this operation when I open the SW3 cam switch the operation stops but it carries on when releasing it. I have no further idea.
barkencoa
  • 3463 Answers
SOURCE: wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Posted on Dec 11, 2008
  • 1294 Answers
SOURCE: Hi my hotpoint aquarius keeps stopping on evry
I hope the below could be helpful, if so you must rate me nice. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Would be good to check out the pump too.
Posted on Jun 05, 2009
prawinmv22
  • 106 Answers
SOURCE: Kenmore Front Load Washer, 417.44082400, will not
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Posted on Jun 12, 2009
pride applia
  • 232 Answers
SOURCE: Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Posted on Aug 02, 2009
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
AMF 82-70 pinsetters
What make, model and year is this vehicle?
Oct 22, 2016 | Cars & Trucks
Need a manual for paragon timer EC 74/120D
Try Googling (paragon)(EC 74/120D)(manual) without parens.
Nov 11, 2013 | Paragon 4001-00 24-hr Timer Control 120v...
A-2 Brunswick Pinsetter: Rake Lift Cam adjustment
try going to brunswick web site to download manual from them ok
Sep 20, 2013 | Computers & Internet
I really need a wirring diagram for a 1974 gas powered amf harley davidson golf cart. thanks for your help!
If you'l Google 'H-D golf carts", you'll get lots dealers that sell the manuals and the schematics are in those. The manuals aren't that expensive and contain all the info you need to fix anything that goes wrong with your cart. Believe me when I tell you that the manual will pay for itself. The reason I say this is because there is NOT ONE THAT WILL WORK ON ONE OF THESE CARTS as far as I know of. The H-D dealers won't even look at one. Since parts are sometimes hard to get, the other cart dealers won't mess with them either. So, you're relegated to doing you own work. You need the manual.
Good luck
Steve
Oct 21, 2010 | Harley Davidson XLS 1000 Motorcycles
AMF Model No. 7008-00 How do I know if it is working or not. Where can I get more Pins to stop the bld everyday at 5pm.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
AMF Cameras constantly not working.
I HAVE THE SAME EXACT CAMERA BUT IT DIDNT COME WITH ALL THAT BUT I HAVE THE SD CARD AND BATTERIES. PLEASE HELP ME.
Aug 09, 2009 | Cameras
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
