Question about Jaton 3DForce4 MX440-8X-64TV (64 MB) Graphic Card
Toshiba cf27c30 The picture is too big to fit on the screen. Heads are cut off as well as the channel info at the bottom. Can you help ? Buy a new one ? How much fix it ? thank !
  • Charles Pilon Aug 07, 2007
    Thanks but I forgot to say the problem is with a television Toshiba cf27c30.
  • 231 Answers
Hi, you only have a setting problem. Go to "Click START, Control Panel,Then click "DISPLAY" When this window opens click settings on top RHS of window. Click "ADVANCED" At the top of this window there will be a dialog box with a setting in it and a drop down to choose another setting. select a setting lower than the one already showing. This will fix your problem. Regards Mistyman
Posted on Aug 07, 2007
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
May 23, 2014 | RCA HD52W56 52" Rear Projection HDTV
Heads are cut off on toshiba tv and reading at bottom
Depending on the model the set or a cable box may have an adjustment for this---simple thing to do also is hook to DVD player via rear inputs to see if same problem or not.
Apr 20, 2012 | Toshiba Televison & Video
The picture is too big for the screen...heads are cut off and guide is cut off on the top when changing channels
Change the aspect ration in the picture menu for a different apperture.
Hope that helps.
Jan 16, 2011 | RCA Televison & Video
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Picture too big.
HDTV's come with selections that will change the screens display, on the remote press the format button and you should be able to find a setting that you desire.
Sep 07, 2008 | Sony KDSR50XBR1 50" Projection HDTV
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
Picture is vertically too big the heads dont fit the screen?
This answer is generic because I do not know the particular model:
You should call the tech support for your set. This may be a fault in the way the address processing is being performed for the display. Sometimes, depending on the model, the service rep can fix this by re-loading the firmware for the set's operation. I have seen failures in the main drive processor for the screen cause this. The solution was to change the board.
Jerry G.
Jan 08, 2008 | Samsung LN-T4665F 46 in. LCD Television
Toshiba cf27c30
It sounds like all you need to do is program your channels into memory. Here is a link to the owners manual; take a look at page 5 and that should answer any other questions you may have
Aug 12, 2007 | Jaton 3DForce4 MX440-8X-64TV (64 MB)...
Jaton 3DForce4 MX440-8X-64TV (64 MB) Graphic Card Logo
70 people viewed this question
Top Jaton Computers & Internet Experts
Chris Larocque
Level 1 Expert
Are you a Jaton Computer and Internet Expert? Answer questions, earn points and help others
