Question about Cingular Wireless 8125 Smartphone
Windows Media cannot read my music "all of a sudden"
My 2gb mini sd card for my pda, which was operating at about 30% of it's capacity, can only read 4 files. I've troubleshooted the setting under system/memory but still no luck. However, my computer can still read all the files that were previously on the card. What else is there to do?
    Guru:
  • 120 Answers
You probably need to reformat the card
Posted on Oct 02, 2007
6ya staff
SOURCE:
My card is not detected when put in to the pc it not opened what i do give me any solution.My memory card is sand disk 2gb micro sd card
It would be a good idea to test the memory in another PC, if the problem continues, the SD has a file system that isn't recognized by your operating system or it has a bad file allocation table, if can be read only from a phone, camera or PDA , and it has data, you can use the corresponding device acting as reader connected to PC using its USB cable to retrieve your data from the card.
Feb 26, 2011 | SanDisk 2GB microSD Memory Card
Will the canon ixus 30 use a 8GB SDHC memory card, as it shows card locked in display
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 11, 2010 | Canon PowerShot SD200 / IXUS 30 Digital...
I just insert a 4G micro card and says card error. Everything else works fine for 3 years ( never put a sd card before ). Thank you in advance Miguel
Check your mini SD card and see if it has the SDHC (high capacity) logo on it. Originally SD cards, including the mini SD, had a 2GB limit by protocol. The DC10 was introduced when this was the most advanced protocol. Since then the SDHC protocol has been introduced, but the DC10 is not compatible with SDHC. You need to get a mini SD, 2GB maximum capacity.
Mar 16, 2010 | Canon DC10 DVD Camcorder
SD memory card error
Please check if it is not an SDHC (larger than 2Gb) card. Some printers can only read SD (2Gb and smaller) while some can also read SDHC (SD High Capacity) cards.
the C4180 can only read 2Gb and smaller (Standard SD)
Feb 28, 2010 | HP PhotoSmart C4180 All-in-One Color...
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
Mini SD card (2gb)
it is not a folder. the file can be found of hte r4ds website and you put it in the root of your mini SD.
Oct 04, 2008 | Nintendo DS Lite Console
SD SLOT WONT READ 4GB MINI SD REG SPEED
try the 4gb card in a camera or phone. If the card is formatted in fat, it wont be recognized as the fat has a gb limit under 4 I believe. May want to reformat it in a camera or phone with fat32
Jan 24, 2008 | Compaq Presario X1000 Notebook
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Can`t read more than 950 MB from 2GB SD Card
Try to format the SD 2GB card with Fat32 to some volumes so u will have multiple drives on the same single SD card. You can do it via card reader and format command from your PC. If this does not help it is possible that the device can not read big size 2GB SD cards.
Nov 12, 2006 | ASUS MyPal A600 Pocket PC
Cingular Wireless 8125 Smartphone Logo
64 people viewed this question
Top Cingular Wireless Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
