Question about Dell Inspiron 15r n5110 Laptop
Fix exe ox0000022 correctly - Dell Inspiron 15r n5110 Laptop
I'm trying to install microsoft picture it on my pc (windows7) but a missing pi.exe keeps on apearing,how can I fix this
Free Guides to Fix PC Errors By PcTweaker Skip to content Leave a replypi.exe is part of Microsoft Picture It! 9 and developed by Microsoft Corporation according to the pi.exe
pi.exe Vendor and Version Informaiton : Product name : Microsoft Picture It! 9 Company : Microsoft Corporation Version : Md5 : 33be8a09351e58d22e5a3f35cff5ffa6 Why does my computer have the pi.exe wrong information cue? pi.exe is a file name that often appears in some error messages on the computer, if you frequently receive the error notifications which state that the specific program cannot be processed for the pi.exe file being corrupted or missing, you should consider to fix pi.exe error well for avoiding the related operation problems on your computer.When this file gets corrupted, missing or suddenly become invalid in the Windows system, you will immediately receive the pi.exe error message and you will need repair it as soon as possbile !
If you do not fix nengine.dll missing as soon as possible, you may face the problems below:
"System boot-up failure" "System file corrupt" "Slow system performance" "Blue Screen of Death errors" "White Screen of Death errors" Why need to Fix pi.exe Errors ? When the system has the pi.exe wrong information, it shows that the error has been affecting the Windows system's running stability. If this time not clearing up the pi.exe error quickly, the Windows registry can be easily damaged, and then the unsteady Windows registry will affect the normal use of other softwares or directly make them not work,and the whole Windows system can not be used normally.So, when the Windows system has the error message, we should hurry up to repair it well.How to fix the pi.exe error ? To fix pi.exe error is not that easy before,but now it is so easy ! Please download the Pctweaker software recommended by us, according to the following procedures. You can soon clear up the pi.exe error through a few simple procedures, and in the course the software will automatically repair your computer's Windows registry damage caused in normal operation.
Jul 23, 2014 | Computers & Internet
When i downloaded adobe acrobat, all i seem to have is a file that opens with text edit and is alot of numbers. What do i do to download it correctly?
The file you have downloaded is OK. The problem is with your PC.
When you double-click an .EXE file, the program may not launch, instead it may open in Notepad (displaying the .exe contents), or may launch in any other application like notepad. It is due to the incorrect .exe file association caused accidentally or probably due to a virus activity and you get the result similar to the following:
SOLUTION
Download EXEFIX-XP
EXE-FIX (VISTA) OR EXEFIX-VISTA
EXEFIX utility and save to Desktop. Double-click the file to run it. This utility fixes the .exe file association in the registry automatically.
You may also use REGISTRY PATCH (for Windows XP)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 12, 2011 | Adobe Acrobat 7.0 Professional
How to play madden without inserting thecd/dvd
Try sites like Game Copy World or Game Burn World for fixed exe. Download the correct version for your game and unzip it. Use this new exe and put it in your games program file. Replacing the exe that is already there.
Oct 12, 2010 | Microsoft Video Game Consoles & Games
I was restoring my computer using Window 7 and get a error message and now I am stuck Can you help me slui.exe application error unable to start correctly (oxoooo7b)
Many users who experience slui exe errors are in the dark about how to fix these types of problems. Fortunately for all of us, the bulk of them can easily be pinpointed and fixed, even if you have very basic technical skills. In the next few paragraphs, I would like to show you how you can effectively do away with these troublesome computer problems.
go trough this link and repair you pc
http://www.topregistrysolutions.com/exe?cd=EXl1792
Sep 02, 2010 | Gateway GT5028 PC Desktop
Computer loads personal settings and then logs off instantly
Sounds like a malware issue I've seen before:
XP logs user off immediately when the user tries to log in - can't get to any desktop
Allegedly 3rd party advertising software Blazefind (homepage and searchbar highjacker)
Fix:
Boot to the Windows XP CD (RAID systems will need the RAID driver floppy during the bootup - hit the F6 key when directed in the bottom message).
Enter the Recovery Console by choosing 'R' at the Welcome to Setup screen.
Choose the OS shown (1) and hit enter.
Hit enter for a blank password if asked for one. If this isn't accepted, make sure that the user is using the correct XP CD (using a PRO version CD for a HOME version install or visa versa will result in a password rejection. If the user has upgraded to PRO over a HOME edition, try booting the HOME CD). If the CD is correct, and the user can't produce the correct Administrator password, then a clean reinstall of the OS (with full data loss) becomes the final answer.
Assuming the user now sees a command prompt, type "CD %systemroot%\system32" (without quotes) and hit ENTER. Normally the %systemroot% default is "c:\windows\" but this depends on if the system defaults were kept or changed during OS installation, of course.
Type "COPY USERINIT.EXE WSAUPDATER.EXE" (again, without quotes) and hit ENTER. This makes a copy of "userinit.exe" and simultaneously names the new copy "wsaupdater.exe".
Type "EXIT" and ENTER. Remove the XP CD while the system is restarting.
The user should now be able to log in normally... but there is one more thing that needs to be done or the issue will repeat itself when the user runs his anti-spyware program again.
Once logged into an administrator account, click the START button.
Choose RUN from the Start Menu.
Enter "REGEDT32" in the OPEN window (notice there is no "i" in edit) and click OK.
By clicking on the + signs next to each branch, click through the tree in the left pane until you get to
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WINDOWS NT\CURRENTVERSION\WINLOGON
Click on the WINLOGON folder in the left pane tree, so that it is highlighted.
Look for "UserInit" in the right pane. It should have a value of "C:\WINDOWS\system32\wsaupdater.exe," (yes, there is a comma at the end of the value). Double-click on "UserInit" and carefully change its value to "C:\WINDOWS\system32\userinit.exe,". Click OK.
Close the Registry Editor. Reboot. Fix is complete. Anti-spyware programs will probably identify and remove "wsaupdater.exe" but the system is no longer using it.
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Cannot launch roxio creator 2009 using desktop icon
If you are running any version of Windows, it's an easy fix, don't worry-
  1. Delete your desktop icon
  2. Using Windows Explorer, go to your C:\Program Files\Roxio folder
  3. Open the Roxio folder, and find the Creator.exe file
  4. Right click on the .exe file, 'create shortcut'
  5. Cut and paste the shortcut you just made onto your desktop.
  6. Try it to make sure it functions correctly.
Oct 03, 2009 | Roxio Creator 2009 Ultimate for PC
Need to reinstall 'cec_main.exe' on toshiba satelite
A viuis caused the problem with that internal file. You need to redo your harddriver by formating it or reinstalling the current operating system with clean install to fix that problem. your system will be strating from the begining as if it was new. GET YOUR DRIVERS FIRST! It's an internal camera file that is the problem and can not be fixed other than reinstallation.
Apr 23, 2009 | ASUS Eee 4G Notebook
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
Dell Inspiron 15r n5110 Laptop Logo
mukhtar21 shaikh
mukhtar21 shaikh
