Question about Transcend TS16GJF500 16GB JetFlash 500 USB 2.0 Flash Drive TS16GJF500
My computer which runs windows 7 gamer addition can not detect my pen drive(jetflash transcent 16 GB) when i use online recovery.exe then the recovery system gives a notification that the device cannot be recognized please take i to yor nearest transcent store or contact transcent customer service but sometime my pen drive is work and when i formet it then it was formeted and work but only for 2 or 3 minite just beacuse readyboot option is active so how can i recover my pen drive again
mayur_best
  • 25 Answers
SOURCE: Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Posted on Jan 29, 2009
coolfixya
  • 82 Answers
SOURCE: drivers for jetflash TS1GJFV30
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#2
here you can find the software..
Posted on Feb 28, 2009
Geekman
  • 32281 Answers
SOURCE: USB 16 GB transcend says disc is write protected!!
You should try to delete the partition in the Transcend memory stick and creat a new partition. You should copy any files that you need off this memory device before you re-partition it because you will lose all the data that is stored on the device.
Go to the Control Panel - Administrative Tools - Computer Management - Disk Magament.
Scroll down until you see your removeable device the 16Gb memory device, click once on this, It may not show it as Healthy.
Right click in this disk (make sure you do not select the C drive) and click on Delete Partition to remove the partition.
Right click on this unpartition drive and Create a partition.
You may not have to format this partition, it should now show this as a healthy drive.
Exit out of Disk/computer Management and Control Panel.
The USB drive should now function normally.
Posted on Mar 07, 2009
SOURCE: I am having Jetflash v10 16 gb model 'Transcend' USB Flash Drive.
Try formatting the drive using NTFS and re -copy your stuffs again. If it fails to copy as you want, then delete the partition and format it again .
Posted on Mar 26, 2009
ChungYu
  • 76 Answers
SOURCE: My 500 GB store jet
You will need to format the disk so the file structure can be read by your operating system. Formating the disk will wipe all data from the disk but will only need to be done once.
Posted on Mar 01, 2011
I want a product information about jetflash v33
Download Links clip_image002.gif JetFlash Online Recovery (for Windows 2000 SP4/ XP SP2/ Vista /7) JetFlash Online Recovery (Only for V15; for Windows 2000 SP4/ XP SP2/ Vista /7) JetFlash Online Recovery (Only for JF620; for Windows 2000 SP4/ XP SP2/ Vista /7) User Manuals for JetFlash Online Recovery
Jan 09, 2013 | Electronics - Others
Transcend 32gb jf v60 pen drive not working
If now you can see your usb drive there might not be any need to do the following
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you might have restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Transcend jetflash recovery
JetFlash Online Recovery is an advanced new software tool specifically developed for Transcend JetFlash USB flash drives.
If your flash drive is not working properly, in most cases it can be repaired instantly by using the recovery tool's simple user-friendly interface.
The JetFlash Online Recovery Tool is conveniently located on the Internet, so no matter where you go, you can service your flash drive 24 hours a day, 7 days a week.
All data on your JetFlash drive will be permanently erased during the repair process.
Please backup the contents of your JetFlash before proceeding.
This software is designed to repair malfunctioning JetFlash USB flash drives.
It will not recover
any data/pictures stored on the device.
Hardware Requirements: USB Port (supports USB2.0), Internet Connection
System Requirements:
Windows XP SP2/ 2000 SP4 or later version(Administrator rights required)
Windows Vista (Administrator rights required, must turn off UAC) To turn off UAC in
Windows Vista, please go to Control Panel > User Account -> Turn User Account Control on or off > and then uncheck ''Use User Account Control to help protect your computer.'' Please remember to restart your PC for the new settings to take effect.
Windows 7 (Administrator rights required, must turn off UAC)
To turn off UAC in Windows 7, please go to
Control Panel -> User Accounts -> Change User Account Control Settings -> change to "Never notify" -> then, Please remember to restart your PC for the new settings to take effect.
Download Links
Manuals (Traditional Chinese)
Manuals (English)
If you need more help with this post a reply
Transcend have a lifetime warranty
Hope this helps.
Nov 27, 2012 | Electronics - Others
My 32 gb transcend pendrive not work how to repair what is problem and where in pune
You have to be the computers Administrator to change any values on any hardware on a computer
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
restore defaults
In XP
It will not recover
Download Links
Manuals (English)
Hope this helps.
Nov 26, 2012 | Electronics - Others
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4gb sony pen drive do not format
Flash drive can not be formatted, there are two possible
To fix Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My trancend 8 gb has become write protected. I used the regidit formula but the problem continued
Flash drive is write-protected, meaning there is damage to the firmware. To repair damaged Transcend firmware, use JetFlash Online Recovery software.
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download)
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
I hope this information helps.
Before repaired
After repair
Oct 06, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i connect transcend jf v30 16 gb pen drive it takes lot of time and computer doesnot respond and it displays as unreadable format or corrpted
There are three possible
3. Bad sector
Oct 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Suddenly usb pen drive stopped recognising
Try using 'JetFlash Online Recovery' .
It is advanced new software specifically developed for Transcend's JetFlash USB flash drives. It repairs your flash drives immediately through simple and user friendly interface. With such effective, safe and reliable solution, it can save your precious time and money bringing your product for traditional RMA service. Wherever you travel, Transcend JetFlash Online Recovery services you 24/7 on the internet.
* Hardware Requirements : USB port (supports USB2.0),Internet connection
* System Requirements : Windows® XP SP2/ 2000 SP4 (Administrator rights required).
Step by Step Instructions
1. Please insert your JetFlash into a PC with internet connection.
2. Run OnLineRecovery.exe and press "START."
3. A confirmation message will be displayed. If you are sure you want to format the JetFlash, press "START." If you do not want to format your JetFlash at this time, please press "EXIT" to quit.
4. The process may take several minutes. Please be patient.
5. When the format is complete, please press "Exit," then unplug the JetFlash and plug it back in to your computer.
voila, its done.
Don't forget to say THANKS
Oct 23, 2010 | Transcend Computers & Internet
Download copy JFSW.exe for JetFlash elite
Driver Installation – Windows® Me, 2000, XP and Vista
No drivers are required. Newer Windows operating systems have built-in drivers that support the JetFlash®. Simply plug your JetFlash® into an available USB port and Windows will automatically install the files needed to use your device. A “Removable Disk” with a newly assigned drive letter will appear in the My Computer window.
JFSW.exe is the older version. You might want to try JetFlash Elite v2.0, a newer more advanced version of JetFlash elite - highly recommended:
http://www.transcendusa.com/Support/DLCenter/Software/Setup_JFSW2.exe
I think you know about this page, but here's a link to save you googling:
/index.asp?axn=SRH2&ModNo=107&ItemID=TS2GJFV30
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Transcend T.sonic 610 MP3 Player
I can not access data on pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 29, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend TS16GJF500 16GB JetFlash 500 USB 2.0 Flash Drive TS16GJF500 Logo
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
