Question about Fisher Paykel EcoSmart GWL15
Pressure switch can you purchase preasure control switch to replace the on board switch fitted on these types of machines or does the conplete control board need to be replaced.
    Top Expert:
  • Fisher Master
  • 42,159 Answers
Contact the spares department of the manufacturer and make enquiries. My feeling is yes as most machines use a generic pressure switch.
Posted on Apr 28, 2013
I have a Kenmore Oasis HE top load washer; purchased it in 2006 and I had the foresight to purchase the master protection plan & extended warranty. I have had SEVERAL repair calls for a variety of...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Jun 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machine stops at start of rinse cycle
Apr 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have kenmore elite oasis, type 580. when starting
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Low oil pressure light is on on 2000 lexus rx300. Doesn't need oil or an oil change. Not leaking oil.
try replacing the oil preasure switch, if that doesnt solve your problem then have your oil preasure tested, if it really doesnt have oil preasure it will cause internal engine damage so start with the switch and then go from there, hope this is helpful.
Nov 29, 2009 | 2000 Lexus RX 300
Keeping getting an F1 error message. what does
it's a glitch with this type of machine. I have same error, did some reasearch this summer and found out there is a class action lawsuit you can join. Won't fix your problem but from what I read, nothing will.
Oct 02, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Keeps shuting off
There are 4 common trouble makers to consider.
One is the switches; it can open circuit and stop the washer. For some reason Maytag has seen fit to discontinue the lock and latch as a complete assembly and will only sell it as individual parts new.
Second is water pressure. If the water pressure is low/poor, the washer will start to fill and then shut off. Check and clean the fill valve entrance screens and also check for any washer screens on either end of the fill hoses. There is a low water pressure fill jumper kit assembly part# 12001482.
The third is possibly the most common trouble maker for this type of a complaint. The fuse blows on the motor control board. This board can be found on the front bottom on the right side. Take apart info. The motor control board must be replaced when the fuse has blown. Most times now the motor control board is replaced with a motor kit - the motor kit Motor/control conversion kit.
The fourth is a bad start switch, sometimes the contacts in the start switch will arc and burn causing starting up problems.
Thank You for contacting Fixya.com
Aug 02, 2009 | Maytag Washing Machines
Kenmore He2Plus 110.47511701 FL Washer F1 code and
Jul 11, 2009 | Kenmore HE2 Plus Front Load Washer
F1 error code washer wont finish cycle have to turn off and on several tries before it goes - purchased 11/5/2006 and only 2.5yrs old not happy any info on who I can contact to have it fixed and or...
Jun 09, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis washer 3rd repair
Jun 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
The door lock led stays flashing even after machine is turned off
Control module probably faulty, this could have failed due to motor problem check for worn carbon brushes in motor.
Oct 29, 2008 | Indesit WA 115 Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
20 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
