Question about Dyson DC39 Animal canister vacuum cleaner
Carpet/hard floor brush scrapes floor loudly
Vacuum was fine for the first few months of usage, but it's now scraping the wood floors and making a lot of noise in the process. It almost seems like something wore off on the brush and now something is scraping by, but I can't see anything when I inspect the brush...besides a ton of scratches on the tool :((
4 Suggested Answers
  • 833 Answers
SOURCE: DC15 - scratching wooden floor
You should have an adjustment to remedy this...it is usually called a pile adjustment and is often found in the area above the beater bar.
Is the bar worn?  Is there something in the bar causing the scratches?
Posted on Nov 27, 2008
b0sslady2001
  • 357 Answers
SOURCE: Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Posted on Aug 07, 2009
Vac Belts
  • 701 Answers
SOURCE: I have a Dyson DC17 that has started making a loud
You need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Dyson DC17 Belt and Manual
Posted on Feb 07, 2010
Just bought a DC33. Multi-floor.It is very hard to push on the carpeting.It is fine on the wood floors.Is there any way to adjust it higher for the carpeting.It is dense carpet not high
There are no floor settings for this unit. Since the brush is spinning, it will create more resistance when running over the carpet.
https://www.dyson.com/support/dc33/dc33-multifloor/flo-dc07-gen-how-to-use-your-dyson/using-brush-control-dc33
Apr 11, 2015 | Vacuums
Squeeling noise dyson 33
Is it when you go from carpet to floor or floor to carpet? It will make a loud noise detecting a possible suction issue. I've also had loud noises and turned over the vacuum and where the brush is, traps hair, thread, rubber bands, etc. Just take a scissor and cut it all out. Don't cut the bristles. Roll the brush as you cut and pull all the stuff wrapped around the brush. Once it is free, try it again.
Jul 27, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
How to fix wheels that raise and lower the beater bar
Hello! The M085845 has an automatic height adjustment that cannot be manually changed. There is a roller lifter assembly that helps to raise and lower the nozzle depending on whether the vacuum is in the upright or reclined position. You do not have to make any adjustments to the vacuum when going from carpet to hard floors. The brushes will continue to spin at all times when the vacuum is in use. Hope this helps!
Jun 26, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do i alter the dyson dc04 to use on hard floors
Hi there, it's Jack at Dyson.
If your DC04 has a brush control on the cleaner head, you'll need to set this to 'On' for carpets, and 'Off' for hard floors. You can find out how to do this on our Support site:
http://www.dyson.co.uk/support/dc04/dc04-brush-control/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-rotate-with-the-power-on
If your machine does not include the brush control, it will only be suitable for vacuuming carpeted surfaces and we'd advise against using it on hard floors in upright mode. However, you can use the hose and wand to vacuum hard floors and we have several suitable hard floor tools available which may help.
I hope this helps - if you'd like further advice you can reach our freephone Helpline on 0800 298 0298. Just to let you know, our Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.co.uk
Mar 06, 2013 | Dyson DC04 HEPA Bagless Upright Cyclonic...
I have just installed travertine floors in my entire house. What's the best vacuume for my floors?
If you have mostly hard floors you can't go wrong with a Miele canister vacuum. They have many models out. I would suggest one with a 14" horse hair floor brush. they are german made and last for years. Don't buy a Dyson they are very harsh on hard floors and your carpet.
May 06, 2011 | Vacuums
Sebo Automatic X1 vacuum 'check brush' light on
I work in a Sebo agency, where we sell and repair Sebos - although they're so reliable we don't get that many to repair.  What's "automatic" about this machine is that it automatically adjusts the brush height so that it's ideal for whatever floor it's on.  It does that by sensing the amount of drag on the brush.  On a wood floor, there's much less drag than on a carpet, so the machine lowers the brush as far as possible to get the optimum drag.  After a while (4 1/2 years in your case) the brush has worn so far that the machine can no longer get it down low enough to brush the floor effectively. That's why the light comes on.  There's still plenty of bristle to do a good job on carpet but, if you want to do the best job on your wood floors too, you need a new brush roller.  Change the brush roller, and you'll probably feel the suction's improved too!
Any questions, just post a comment and I'll help if I can.  I value your feedback so please remember to rate this response.
May 04, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Dyson vacuum cleaner ...upright....all of a sudden my vacuum started making this awful sound...like a loud buzz...but only when I have it on carpet....when I have it on "floor" mode it's...
it may just be, that on carbet the brushes make noise that you dont hear on woodfloors.
If there is a hights adjustment, set it higher for shaggy carpet and lower for berber.
Mar 16, 2008 | Vacuums
Dyson DC39 Animal canister vacuum cleaner Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
