Function lg m2262dl
My fn key doesn't working for shortcut
  • 826 Answers
Pop the key out and then insert it back.
Posted on May 01, 2013
Not able to use the 'FN' key for all its functions
Sorry you would need to contact Microsoft windows support staff.
Jul 28, 2017 | Sony Computers & Internet
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
The fn keys dont work in my asus except for the fn+f7 one. when i press fn+f2 the led light goes on and off but it doesn't seem to work??? what should i do??
Hook a external keyboard to the laptop, if all functions checkout. The keyboard in the laptop will need to be replaced..
Mar 30, 2012 | ASUS Computers & Internet
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
My computer laptop model is Toshiba satellite P750. The FN key doesn't work. Nothing happen when i touch it.
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
http://www.ehow.com/list_5941452_laptop-keyboard-functions.html
Aug 27, 2011 | Computers & Internet
Hi I have just bought an Acer Aspire Z5710 all-in-one PC. I find the screen too bright when working for long, and want to adjust the brightness. But i am not able to figure out how to do so. And there...
http://support.acer.com/acerpanam/Manuals/acer/2011/ServiceGuides/SG_Aspire_Z5700_Z5710_20100907.pdf
If the keyboard doesn't have a Fn key often the Scroll Lock key is used, try Scr Lk + Down arrow to dim the display.
The manual indicates and Fn Key to the right of the Left Alt Key but that doesn't mean you have that keyboard eitther
Jun 30, 2011 | Computers & Internet
It will on but there is no display
It's possible you accidentally switched the display output with the keyboard shortcuts. if you look on your keyboard you'll see a key labeled "Fn" the function key will allow you to enable or disable certain features. the shortcuts are usually blue or grey pictures on the Function keys at the top of the keyboard. for example, my laptop can the wireless radio on or off by press Fn and F2 at the same time. you should have a key that says LCD or has a picture of a monitor (for my laptop it's F6) but every brand is different.
It's also possible the backlight on the LCD panel has failed. if move the laptop screen in a well lit room, you may vaguely see your background. If so, you'll have to contact Asus if the laptop is under warranty for repairs, or take the computer to a computer shop. The LCD panel needs to be replaced and can cost you anywhere from $150-$300 for service and repair if not warranted.
May 03, 2011 | ASUS Computers & Internet
(Fn) key function
Fn or Function key is used for your F1 up to F12 keys. Ex. Fn+F5 is to turn on the wireless capability. Fn key is like a shortcut for the functionality of the machine. You can also adjust brightness by pressing Fn+Up or Down arrow and for the Volume Fn+Left and Right arrow.
Apr 29, 2011 | Lenovo IdeaPad Z360 Notebook
Some of my function key shortcuts have stopped working
go to asus website and click support. after that click download and find the ATK file...I tried both, but I believe the larger file is the one working
Oct 19, 2009 | ASUS Eee 4G Notebook
Acer shortcut keys do not work?
Function keys? Try holding down the Fn key and the shortcut key.
Aug 26, 2009 | Acer Aspire 5720-6661 Notebook PC
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
