Question about Philips Pocket Memo 388 Handheld Cassette Voice Recorder
Manual how to transfer cassette to cd
Do I need to drain the oil from my transmission when removing my transfer case?
USUALLY the transfer case is independent from the trani. do they have separate Drain plugs?
Mar 02, 2016 | OEM 1991 Chevy K1500 Pickup Radio / CD...
How can I get an instruction manual?
Recording from tape is very similar to recording from the turntable, but you have to select tape as the source. There will be a button labelled something like PHONO/TAPE/AUX with which you select TAPE and then record as you would for a vinyl disc but you press play on the tape instead of playing a record. Here's something very similar which should help you. Good luck and I hope you get to save your memories.
http://www.teac.com/content/downloads/products/755/lp-r550usb_om_efs_va.pdf
May 12, 2014 | ANDERS NICHOLSON USB Turntable With CD...
Instruction Manual for model 2034
there is no manual,
Tape-2-MP3 Converter/Player
Convert your cassette tapes to Audio CD or MP3 files with 3 simple steps! Connect portable cassette player/converter to PC or Mac via USB cable. Transfer by Installing provided software and simply press "RECORD" while playing the tape. Create MP3 files from transferred audio to burn to CD or import to iTunes for use on your iPod device.
USB-to-Computer Recording
Convert from cassette to digital formats directly to your PC or Mac computer via USB cable and simple Audicity® software, both included.
Feb 17, 2014 | Encore Technology Portable Cassette...
CANT TRANSFER CASSETT TO CD
Hi Margaret,
You can download the manual for this device here. The downloaded file is called "ad-rw900.pdf" and should be found in your download directory.
Locate and open the file (Adobe Reader) and review page 31. Here you'll find the details to go about recording a CD from the source you've selected with the "Input Select" button. When recording to a CD-R or CD-RW with a cassette TAPE (or LINE IN or PHONO) as the source, you must manually set the recording level as directed in step 5 on page 32. Check the blank recording media. The device is ONLY capable of recording on "CD-R" and rewritable "CD-RW" blanks (these are very different from DVDs of any type). The CD-R type will likely enjoy wider compatibility (than CD-RW types) when played back on a different (car or other) CD player.
I hope this helps & good luck!
Dec 16, 2013 | Teac AD-RW900 CD Recorder and Auto Reverse...
Convert cassets to cds on classic recorder model cdr200
Connect the Play or out from the cassette and connect to the rec or in on the CD recorder using some descent RCA cables. Good luck!
Jan 13, 2013 | Classic Electronics CDR201 CD Recorder
The CD player no longer works in my 2005 KIA Sportage
Have you tried different cd's?I f so then the loading tray may be at fault.If you don't want to fix it here is a solution.Buy a cassette adapter with a 3.5 mm connector and use a mp3 player you can transfer your cd collection to your mp3 player via you computer
Oct 17, 2017 | 2005 Kia Sportage
Can I easily transfer data ie audio files from recorded music cassettes to the CD or USB with any of Sony cd/cassette player?
Cassettes don't contain 'files' or data.
The analog audio can be recorded to a CD.
For this specific model, it's all in the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RCD150-Boomboxes-manual/id/402ci674/t/2/
No usb on this one.
Feb 23, 2011 | RCA RCD150 Radio/Cassette/CD Boombox
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
How do I open a Maxell mini DV tape case? I have one cassette that is broken - tape is fine - I need to transfer the tape reels to a new cassette. Same brand of cassette.
Hello FixYa, I was able to find a post in the internet to help. While you service is convenient, the cost and my immediate need really dictated my continued search. Thank-you anyways for your time.
Aug 11, 2008 | Maxell CD-R 80 Minute 700MB Media...
Philips Pocket Memo 388 Handheld Cassette Voice Recorder Logo
29 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
