Question about Dell Computers & Internet
Battery error code 3600:0852 - Dell Computers & Internet
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 63 Answers
Usually this has to do with physical damage to the battery or the connection of the battery to the motherboard. Try looking for some sort of physical fault where the battery connects to the computer.
Posted on Apr 28, 2013
Error code 1500
The error code P1500 means there was a problem "Alternator FR teminal circuit"
Was the battery jump started recently or battery gone dead? This code condition tends to be intermittent especially when a jump start was given
Jun 12, 2015 | Chrysler Sebring Cars & Trucks
Battery Error Code:2000-0133
This error code shows that the battery has got completely damaged or about to damage. the last thing, if you are using a duplicate battery, or no battery in system, then also it can show you the same error. You need a new original battery for your system.
Oct 15, 2013 | Dell Inspiron 9100 Notebook
Error code p062b 2012 equinox
Had the same problem on our 2012 Equinox today. Threw codes P026B and P062F. Appears to be a bad battery. Replaced battery and all seems ok now...keeping fingers crossed. My suspicion is that the faulty, dying battery caused a low voltage situation in the injector control module and thus those errors. Will see if the check engine light returns in the next 48 hours.
Apr 20, 2013 | 2012 Chevrolet Equinox LS 4dr SUV 2.4L...
What is error code 161
http://www.howtomendit.com/answers.php?id=12813
It is all explained above, and more.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=lwik-3sr4pw
Above are the error codes and explanations.
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
http://www-307.ibm.com/pc/support/site.wss/LWIK-3RUQGS.html
Above is your support link, so you can download a manual etc.
Sep 22, 2010 | IBM ThinkPad 600E 2645 Notebook
I am getting an error code of 00161 and 00163 on my ibm think pad 2635
Error code 161 means your CMOS battery is dead and 163 is that system date and time are not set (which make sense as the CMOS battery is dead).
You need to replaced your CMOS motherboard battery to resolved this issue.
May 19, 2010 | IBM ThinkPad 380ED
What does the error-code E50 means in a crayola Kiddycam 25070?
hi,
The "E50" error code indicates formatting a storage card has failed.I think the e50 error code happens when the camera is reading and/or writing to the CF card when the battery are dead or real low. The camera does not get to finish writing data and leaves an error on the CF card. Use new battery or fully charged battery. I hope this may help you,
regards,
kaybicks
Feb 27, 2010 | Cameras
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code 1684
Error code Number P1684 Battery Disconnected Within Last 50 Starts. Check battery and connections.
Nov 16, 2008 | 1999 Dodge Intrepid
Error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Nov 19, 2007 | Sony Handycam DCR-TRV80 Mini DV Digital...
Computers & Internet Logo
85 people viewed this question
Alun Cox
